Dell Latitude E6400 RAM Replacement
    1. Dell Latitude E6400 RAM Replacement, RAM: step 1, image 1 of 2 Dell Latitude E6400 RAM Replacement, RAM: step 1, image 2 of 2
      • Simultaneously slide the battery latches (outlined by the red box) to the dock connector in the middle.
      • This will release the battery. Just slide the battery away from the computer.
      • Open up the computer and press and hold the power button for 5 seconds. This drains any power left inside the computer.
      • This is important, as if electricity remains in the notebook, it can shock you and damage the logic board.
      Ask FixBot
    2. Dell Latitude E6400 RAM Replacement: step 2, image 1 of 2 Dell Latitude E6400 RAM Replacement: step 2, image 2 of 2
      • Loosen the center screw with a philips screw driver. This is the only screw that needs to be loosened.
      • It can't be removed as it is captive the the bottom plate.
      • Now slide the plate away from the dock connector.
      Ask FixBot
    3. Dell Latitude E6400 RAM Replacement: step 3, image 1 of 2 Dell Latitude E6400 RAM Replacement: step 3, image 2 of 2
      • Locate the RAM slot.
      • the system can hold 2 RAM modules.
      • This unit has 1 module. It is a 1GB one.
      • Push the metal spreaders (shown in the blue rectangle) straight away from the RAM module.
      • The RAM module should pop up to a 45 degree angle.
      Ask FixBot
    4. Dell Latitude E6400 RAM Replacement: step 4, image 1 of 1
      • Pull the RAM module straight out from the way it was raised. (Once it pops up to a 45 degree angle, pull it straight out from its current position).
      • Insert the new RAM into the empty slot, ensuring that the notch in the RAM lines up with the slot (see picture).
      Ask FixBot
    5. Dell Latitude E6400 RAM Replacement: step 5, image 1 of 2 Dell Latitude E6400 RAM Replacement: step 5, image 2 of 2
      • Slide the bottom plate on.
      • Slide it to the rear of the notebook. (battery compartment)
      • tighten the screw.
      • Do not over-tighten. Doing so will strip the screw.
      Ask FixBot
    6. Dell Latitude E6400 RAM Replacement: step 6, image 1 of 2 Dell Latitude E6400 RAM Replacement: step 6, image 2 of 2
      • Slide the battery in until it clicks.
      • Press the power button.
      • AND it works.
      Ask FixBot
19 other people completed this guide.
Nicholas Ouimet
3,700 Reputation
11 Guides authored
9 Guide Comments
I assume that in Step 4, you install the new memory modules
Peter Bourke - Reply Share
When/how to fit the new memory modules is unclear. I have a blue flashing A light and can't start up. Looking for solutions.
Linda - Reply Share
It would be helpful to add a link to troubleshooting info here
Linda - Reply Share
Instead of "assuming" why not READ all of Step 4; especially the second paragraph, which states: "Insert the new RAM into the empty slot, ensuring that the notch in the RAM lines up with the slot (see picture)."
Nadaword - Reply Share
In my case, I needed to add a second memory board (2nd memory slot). If possible, would be interesting to have this additional step included in the guide.
Pedro Pontes - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 45
All Time: 51,172
