Dell Latitude E6330 Keyboard Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
23
Past 30 Days:
83
All Time:
1,610
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
The Dell Latitude E6330 is a durable and reliable business laptop, but over time, the keyboard may experience wear and tear from heavy usage. Whether you’re dealing with unresponsive keys, sticky buttons, or a cracked keyboard, replacing it can breathe new life into your device.
This guide will walk you through the process of safely removing and replacing the keyboard on a Dell Latitude E6330, ensuring minimal risk to other components.
Before beginning, make sure to power off the laptop, disconnect the battery, and have the necessary tools on hand. With this guide, you’ll have your laptop back to peak performance in no time!
Tools
    1. Dell Latitude E6330 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Dell Latitude E6330 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Start by flipping the laptop over and removing the two, deeply recessed, 2.5mm x 5mm screws from the bottom face of the laptop.
      Ask FixBot
    2. Dell Latitude E6330 Keyboard Replacement: step 2, image 1 of 3 Dell Latitude E6330 Keyboard Replacement: step 2, image 2 of 3 Dell Latitude E6330 Keyboard Replacement: step 2, image 3 of 3
      • Grab a plastic spunger and slowly pop out the keyboard bezel from around the keyboard.
      Ask FixBot
    3. Dell Latitude E6330 Keyboard Replacement: step 3, image 1 of 1
      • Locate and remove the remaining three 2mm x 3mm screws connecting the keyboard to the frame. (One is located just left of the left mouse button and the remaining two are just right of the right mouse button).
      Ask FixBot
    4. Dell Latitude E6330 Keyboard Replacement: step 4, image 1 of 3 Dell Latitude E6330 Keyboard Replacement: step 4, image 2 of 3 Dell Latitude E6330 Keyboard Replacement: step 4, image 3 of 3
      • At this time you should be able to gently lift the keyboard off of the frame and expose a ribbon cable connecting it to the motherboard. Flip up the clip holding the ribbon in place and remove the faulty keyboard.
      • When connecting the new ribbon cable make sure you gently slide it into its slot before locking the latch back down to ensure it is properly connected.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Brett Murray
450 Reputation
3 Guides authored
1 Guide Comment
That's the way to do it!
goran ninkovic - Reply Share
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 83
All Time: 1,610
