Up to 20% off select tools
Dell Latitude E5520 RAM Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
16
Past 30 Days:
64
All Time:
401
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
There are two main reasons that you would need to replace your ram. The first one being that you want an upgrade and want your laptop to run smoother, or that your current laptop is experiencing issues such as system crashes, unexpected reboots, or memory issues. By fixing these issues or upgrading, you can significantly boost overall performance. This guide is very simple and should only take around 10 minutes.
Before you begin, ensure that the battery is unplugged and disconnected to any electricity.
    1. Dell Latitude E5520 RAM Replacement, RAM: step 1, image 1 of 3 Dell Latitude E5520 RAM Replacement, RAM: step 1, image 2 of 3 Dell Latitude E5520 RAM Replacement, RAM: step 1, image 3 of 3
      • Remove the five 2.5x5 mm Phillips screws that secure the lower case.
      Ask FixBot
    2. Dell Latitude E5520 RAM Replacement: step 2, image 1 of 3 Dell Latitude E5520 RAM Replacement: step 2, image 2 of 3 Dell Latitude E5520 RAM Replacement: step 2, image 3 of 3
      • Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Pull the RAM module directly out of its socket.
      • Repeat the previous bullet for the other RAM module.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Brandon Froidcoeur
423 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 64
All Time: 401
