Dell Latitude E5500 Wireless Card Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
0
Past 7 Days:
16
Past 30 Days:
80
All Time:
1,786
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the user would like to replace a faulty wireless card, or one that is not powerful enough, this guide will give step by step information on how to achieve this.
Tools
    1. Dell Latitude E5500 Wireless Card Replacement, Wireless Card: step 1, image 1 of 1
      • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
      Ask FixBot
    2. Dell Latitude E5500 Wireless Card Replacement: step 2, image 1 of 2 Dell Latitude E5500 Wireless Card Replacement: step 2, image 2 of 2
      • Place your hands on the plate and pull it toward yourself.
      • The plate will pop out of place and may then be removed.
      Ask FixBot
    3. Dell Latitude E5500 Wireless Card Replacement: step 3, image 1 of 2 Dell Latitude E5500 Wireless Card Replacement: step 3, image 2 of 2
      • The wireless card is located near the front of the device, and is the expansion card with three antennas attached to it.
      Ask FixBot
    4. Dell Latitude E5500 Wireless Card Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the wires connecting the card to the laptop with a pair of tweezers.
      Ask FixBot
    5. Dell Latitude E5500 Wireless Card Replacement: step 5, image 1 of 1
      • Unscrew the 4mm Phillips #1 screw that secure the card in place.
      Ask FixBot
    6. Dell Latitude E5500 Wireless Card Replacement: step 6, image 1 of 2 Dell Latitude E5500 Wireless Card Replacement: step 6, image 2 of 2
      • After completing steps 4 & 5, the card will lift up at an angle as shown.
      • Once the card has popped out of place, it can be gently removed.
      Ask FixBot
3 other people completed this guide.
Richard Harrison
823 Reputation
4 Guides authored
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 80
All Time: 1,786
