Dell Latitude E4310 RAM Replacement
    1. Dell Latitude E4310 RAM Replacement, Battery: step 1, image 1 of 1
      • Power down the laptop and remove all power cords.
      Ask FixBot
    2. Dell Latitude E4310 RAM Replacement: step 2, image 1 of 2 Dell Latitude E4310 RAM Replacement: step 2, image 2 of 2
      • Push in the battery release button with your thumb.
      • Pull up on the battery to remove.
      Ask FixBot
    1. Dell Latitude E4310 RAM Replacement, Memory Door: step 3, image 1 of 2 Dell Latitude E4310 RAM Replacement, Memory Door: step 3, image 2 of 2
      • Unscrew the two 4mm Phillips #1 screws.
      Ask FixBot
    2. Dell Latitude E4310 RAM Replacement: step 4, image 1 of 2 Dell Latitude E4310 RAM Replacement: step 4, image 2 of 2
      • Lift up the panel with your finger.
      • The screws are clipped to the panel and will remain attached.
      Ask FixBot
    1. Dell Latitude E4310 RAM Replacement, RAM: step 5, image 1 of 2 Dell Latitude E4310 RAM Replacement, RAM: step 5, image 2 of 2
      • Pry the two metal clips away from the RAM module until the module pops out of place.
      Ask FixBot
    2. Dell Latitude E4310 RAM Replacement: step 6, image 1 of 2 Dell Latitude E4310 RAM Replacement: step 6, image 2 of 2
      • Slide the RAM backwards out of its socket to remove.
      Ask FixBot
    3. Dell Latitude E4310 RAM Replacement: step 7, image 1 of 2 Dell Latitude E4310 RAM Replacement: step 7, image 2 of 2
      • Repeat steps 1 and 2 to remove the second RAM module.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 67
All Time: 1,615
