Dell Latitude E4200 RAM Replacement
    1. Dell Latitude E4200 RAM Replacement, Back Panel: step 1, image 1 of 1
      • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
      Ask FixBot
    2. Dell Latitude E4200 RAM Replacement: step 2, image 1 of 3 Dell Latitude E4200 RAM Replacement: step 2, image 2 of 3 Dell Latitude E4200 RAM Replacement: step 2, image 3 of 3
      • Place thumbs flat on the front side of the back panel (the side to open the laptop).
      • Push panel upwards sliding it out of the locked position.
      • Lift panel out of socket.
      Ask FixBot
    3. Dell Latitude E4200 RAM Replacement: step 3, image 1 of 1
      • Remove panel and screw from the device. This opens up the main board of the device.
      Ask FixBot
    1. Dell Latitude E4200 RAM Replacement, Remove the back panel: step 4, image 1 of 1
      • Once you removed the back panel, the RAM will easily be located.
      • Be sure to remove the battery first
      Ask FixBot
    2. Dell Latitude E4200 RAM Replacement, Take out the RAM: step 5, image 1 of 2 Dell Latitude E4200 RAM Replacement, Take out the RAM: step 5, image 2 of 2
      • Place your thumbs on each side of the RAM tabs.
      • Gently push outward on the tabs to release the RAM. This will allow you to remove the RAM completely from your device.
      • The RAM should "bump up" after you push away the tabs.
      Ask FixBot
    3. Dell Latitude E4200 RAM Replacement: step 6, image 1 of 3 Dell Latitude E4200 RAM Replacement: step 6, image 2 of 3 Dell Latitude E4200 RAM Replacement: step 6, image 3 of 3
      • Gently grab each side of the RAM and remove it from the device.
      • Please do not touch connection side of the RAM (shown in orange) with fingers. It might causes possible corrosion to the connection.
      Ask FixBot
2 other people completed this guide.
Chao Wei
146 Reputation
1 Guide authored
Baylor, Team 5-6, Williams Spring 2015 Member of Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 97
All Time: 3,239
