Dell Latitude E4200 Keyboard Replacement
    1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: step 1, image 1 of 1
      • Open computer.
      Ask FixBot
    2. Dell Latitude E4200 Keyboard Replacement: step 2, image 1 of 1
      • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
      • A small flat head screwdriver would be an ideal tool to use during this step.
      Ask FixBot
    3. Dell Latitude E4200 Keyboard Replacement: step 3, image 1 of 1
      • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
      Ask FixBot
    1. Dell Latitude E4200 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Use a PH00 screwdriver to unscrew the screw.
      Ask FixBot
    2. Dell Latitude E4200 Keyboard Replacement: step 5, image 1 of 2 Dell Latitude E4200 Keyboard Replacement: step 5, image 2 of 2
      • Use your hands to gently lift the keyboard from the device.
      Ask FixBot
    3. Dell Latitude E4200 Keyboard Replacement: step 6, image 1 of 1
      • Gently turn the keyboard over.
      Ask FixBot
    4. Dell Latitude E4200 Keyboard Replacement: step 7, image 1 of 1
      • Be careful not to disconnect the keyboard connector.
      Ask FixBot
    5. Dell Latitude E4200 Keyboard Replacement: step 8, image 1 of 1
      • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
      Ask FixBot
    6. Dell Latitude E4200 Keyboard Replacement: step 9, image 1 of 1
      • Completely lift the keyboard from the device, as they are now disassembled.
      Ask FixBot
3 other people completed this guide.
Michelina Carbone
197 Reputation
1 Guide authored
Baylor, Team 5-6, Williams Spring 2015 Member of Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 105
All Time: 4,859
