Dell Latitude D830 Keyboard Replacement
    1. Dell Latitude D830 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Orient the laptop so that the back is facing you.
      • With a phillip's head screwdriver, remove the two screws on the back corners of the laptop.
      Ask FixBot
    2. Dell Latitude D830 Keyboard Replacement: step 2, image 1 of 1
      • Flip the laptop over, with the opening still facing up.
      • With a phillip's head screwdriver remove the two screws in the upper two corners.
      Ask FixBot
    3. Dell Latitude D830 Keyboard Replacement: step 3, image 1 of 1
      • Open the laptop up. Displaying the keyboard and screen.
      • Take a spudger and insert it under the left edge of the panel between the keyboard and screen.
      • Use the spudger to pry under the panel.
      Ask FixBot
    4. Dell Latitude D830 Keyboard Replacement: step 4, image 1 of 1
      • Place the spudger under the middle of the panel and use it to pry the panel off.
      Ask FixBot
    5. Dell Latitude D830 Keyboard Replacement: step 5, image 1 of 1
      • Place the spudger under the right side of the panel and use it to pry the panel off.
      • For additional help the spudger can be placed around the edge of the panel and used to pry it off.
      Ask FixBot
    6. Dell Latitude D830 Keyboard Replacement: step 6, image 1 of 1
      • After you have the panel popped out, then you must pull the screen up as shows in the picture.
      Ask FixBot
    7. Dell Latitude D830 Keyboard Replacement: step 7, image 1 of 1
      • The screen will only be connected by the wiring.
      • Take the screen and gently place it on the table as shown in the picture.
      • Now you must remove the three screws highlighted in the picture.
      Ask FixBot
    8. Dell Latitude D830 Keyboard Replacement: step 8, image 1 of 1
      • After removing the three screws, slide the keyboard out so the mainframe of it is loose.
      • The a component still attached at the bottom.
      Ask FixBot
    9. Dell Latitude D830 Keyboard Replacement: step 9, image 1 of 1
      • The highlighted item should be the only component holding the keyboard on.
      Ask FixBot
    10. Dell Latitude D830 Keyboard Replacement: step 10, image 1 of 1
      • Where the rectangle is, there is a silver lever that you must push back.
      • Then where the circle is on the photo, you must take the spudger and push in.
      • This will then pop the white clip off and the keyboard will be free.
      Ask FixBot
    11. Dell Latitude D830 Keyboard Replacement: step 11, image 1 of 1
      • The keyboard is now completely detached, and is ready to be replaced.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 59
All Time: 1,329
