Dell Latitude D820 Keyboard Replacement
    1. Dell Latitude D820 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Remove the charger from the laptop.
      • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
      • If you are replacing other components, leave the battery out.
      • If you are only replacing the battery, reverse the steps to install a new battery.
      Ask FixBot
    1. Dell Latitude D820 Keyboard Replacement, Keyboard: step 2, image 1 of 3 Dell Latitude D820 Keyboard Replacement, Keyboard: step 2, image 2 of 3 Dell Latitude D820 Keyboard Replacement, Keyboard: step 2, image 3 of 3
      • Open laptop lid and extend screen until it is parallel with the keyboard.
      • Locate the notch in the upper right corner of the keyboard (just above the 'page up' button).
      • Insert the plastic spudger and very gently lift the faceplate. It will make a soft snapping sound.
      • Set aside.
      Ask FixBot
    2. Dell Latitude D820 Keyboard Replacement: step 3, image 1 of 1
      • Locate the three philips head screws above the keyboard. One is above the 'Pause/Break' key; one above the F7 key and one above the 'Esc' key. Remove all three.
      Ask FixBot
    3. Dell Latitude D820 Keyboard Replacement: step 4, image 1 of 1
      • Gently lift top of keyboard and lay forward on palm rest.
      • Locate blue pull tab and gently disconnect ribbon cable from motherboard.
      Ask FixBot
5 other people completed this guide.
Michael Coleman
162 Reputation
1 Guide authored
Pasco Hernando, Team 1-2, Prince Fall 2014 Member of Pasco Hernando, Team 1-2, Prince Fall 2014
PHSC-PRINCE-F14S1G2
10 Members
84 Guides authored
4 Guide Comments
I am the author of a high-altitude cookbook. I self-publish. My "A" key decided to stop working on my dell XP, and then the internet would not connect. When I finally purchased a new computer Windows 8, I discovered I could not format it for my hp business injet 2300. This printer is a duplexer, and key to my cookbook business. The other problem was Quark Express 6.1 would not work on it. Two thousand plus seemed a little high for a new Quark. After fiddling around with the internal keyboard and using the "copy and replace function" I decided on a new keyboard. Found a new one on ebay cheap. The instructions here were a blessing. Thank you, thank you, thank you! I now have my XP back working like new. The Windows 8 can be for the internet,
DAWN KLEIN - Reply Share
Thank you very much. I am glad it helped and your back up and running. Just a side note: Be careful using Windows XP on the Internet these days, since it no longer receives security updates from Microsoft. Thanks again!
Henry - Reply Share
You gave great directions. I never reassembled something I took apart. Worked like a charm Thanks so much!!!
Cheryl Baynard - Reply Share
Beautifully clear - perfect! Thank you.
David Harmsworth - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 113
All Time: 2,798
