Dell Latitude D630 RAM (Slot B) Replacement
    1. Dell Latitude D630 RAM (Slot B) Replacement, Battery: step 1, image 1 of 1
      • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
      • Turn the laptop over so its bottom is facing you.
      • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
      Ask FixBot
    2. Dell Latitude D630 RAM (Slot B) Replacement: step 2, image 1 of 1
      • Using two index fingers, slide the battery latches outward.
      • While still holding the latches out, use your thumbs to slide the battery out towards you.
      • Once the battery is dislodged, you can let go of the latches and remove the battery.
      Ask FixBot
    1. Dell Latitude D630 RAM (Slot B) Replacement, RAM (Slot B): step 3, image 1 of 1
      • Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
      Ask FixBot
    2. Dell Latitude D630 RAM (Slot B) Replacement: step 4, image 1 of 1
      • Use your fingers to push out the latches holding the RAM in place.
      • The RAM should now sit up at an angle so you can safely remove it.
      Ask FixBot
To install the new RAM, set it in the slot at an angle and push it in until the latches reclick.
14 other people completed this guide.
Jon Amireh
1,746 Reputation
8 Guides authored
Cal Poly, Team 6-1, Johann Winter 2013 Member of Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Members
101 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 110
All Time: 6,721
