Dell Latitude D630 Battery Replacement
    1. Dell Latitude D630 Battery Replacement, Battery: step 1, image 1 of 1
      • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
      • Turn the laptop over so its bottom is facing you.
      • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
      Ask FixBot
    2. Dell Latitude D630 Battery Replacement: step 2, image 1 of 1
      • Using two index fingers, slide the battery latches outward.
      • While still holding the latches out, use your thumbs to slide the battery out towards you.
      • Once the battery is dislodged, you can let go of the latches and remove the battery.
      Ask FixBot
To install your new battery, follow the steps in reverse order and slide your new battery in.
14 other people completed this guide.
Justin Ng
166 Reputation
1 Guide authored
Cal Poly, Team 6-1, Johann Winter 2013 Member of Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Members
101 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 136
All Time: 10,389
