Up to 20% off select tools
Dell Latitude D620 RAM Replacement
Views: 36K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
107
All Time:
35,740
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 16
16 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Guide to installing new RAM modules for the Dell Latitude D620.
    1. Dell Latitude D620 RAM Replacement, Keyboard: step 1, image 1 of 1
      • Power down the laptop and remove the battery.
      • Open the laptop cover all of the way.
      Ask FixBot
    2. Dell Latitude D620 RAM Replacement: step 2, image 1 of 3 Dell Latitude D620 RAM Replacement: step 2, image 2 of 3 Dell Latitude D620 RAM Replacement: step 2, image 3 of 3
      • Locate the notch under the cover at the top of the keyboard
      • Using the spudger as a lever, lift the plastic covering
      • Carefully remove the rest of the covering from right to left
      Ask FixBot
    3. Dell Latitude D620 RAM Replacement: step 3, image 1 of 1
      • Unscrew the top portion of the keyboard using a #00 screwdriver
      Ask FixBot
    4. Dell Latitude D620 RAM Replacement: step 4, image 1 of 1
      • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
      • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
      Ask FixBot
    5. Dell Latitude D620 RAM Replacement: step 5, image 1 of 2 Dell Latitude D620 RAM Replacement: step 5, image 2 of 2
      • Once keyboard is out of the case, lay it face-down on the track pad
      Ask FixBot
    6. Dell Latitude D620 RAM Replacement: step 6, image 1 of 2 Dell Latitude D620 RAM Replacement: step 6, image 2 of 2
      • Using a small spudger, pull back on the black bar to release the blue lever
      Ask FixBot
    7. Dell Latitude D620 RAM Replacement: step 7, image 1 of 1
      • Pull up on the metal bar connected to the socket to detach the ribbon cable
      Ask FixBot
    1. Dell Latitude D620 RAM Replacement, RAM: step 8, image 1 of 2 Dell Latitude D620 RAM Replacement, RAM: step 8, image 2 of 2
      • With the keyboard removed, you should be able to see ram slot A.
      • Place new ram into the slot making sure it is aligned
      Ask FixBot
    2. Dell Latitude D620 RAM Replacement: step 9, image 1 of 1
      • Replace the keyboard by following the previous steps in reverse
      • Close the laptop, and flip it over onto its backside
      Ask FixBot
    3. Dell Latitude D620 RAM Replacement: step 10, image 1 of 2 Dell Latitude D620 RAM Replacement: step 10, image 2 of 2
      • Loosen the screw that holds the RAM cover in place.
      • The screw cannot be fully removed since it is attached to the RAM cover.
      Ask FixBot
    4. Dell Latitude D620 RAM Replacement: step 11, image 1 of 2 Dell Latitude D620 RAM Replacement: step 11, image 2 of 2
      • Insert new ram into slot B
      Ask FixBot
26 other people completed this guide.
Author
with
Miguel Wong
565 Reputation
3 Guides authored
Cal Poly, Team 24-35, Regan Spring 2010 Member of Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Members
48 Guides authored
2 Guide Comments
If you are increasing the amount of RAM installed -> On first power on after installing the RAM, system on boot up will complain about memory size changed, and to reseat the memory. Wait for about 60 - 90 seconds, and you will receive a few additional messages about F1 to continue or F2 for Setup. Go into Setup and verify that the system sees all memory installed. If installing 2 x 2GB DDR2, max possible, 4GB. BIOS setup should report 4GB installed, of which 3.37GB usable.
Michael Erwin - Reply Share
J’étais inquiet, mais en lisant votre commentaire, me voilà rassuré et j’ai donc suivi vos instructions. Ca fonctionne 2X2 GO …Merci
ppgauchard - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 107
All Time: 35,740
