Dell Latitude D620 Keyboard Replacement
    1. Dell Latitude D620 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Power down the laptop and remove the battery.
      • Open the laptop cover all of the way.
      Ask FixBot
    2. Dell Latitude D620 Keyboard Replacement: step 2, image 1 of 3 Dell Latitude D620 Keyboard Replacement: step 2, image 2 of 3 Dell Latitude D620 Keyboard Replacement: step 2, image 3 of 3
      • Locate the notch under the cover at the top of the keyboard
      • Using the spudger as a lever, lift the plastic covering
      • Carefully remove the rest of the covering from right to left
      Ask FixBot
    3. Dell Latitude D620 Keyboard Replacement: step 3, image 1 of 1
      • Unscrew the top portion of the keyboard using a #00 screwdriver
      Ask FixBot
    4. Dell Latitude D620 Keyboard Replacement: step 4, image 1 of 1
      • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
      • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
      Ask FixBot
    5. Dell Latitude D620 Keyboard Replacement: step 5, image 1 of 2 Dell Latitude D620 Keyboard Replacement: step 5, image 2 of 2
      • Once keyboard is out of the case, lay it face-down on the track pad
      Ask FixBot
    6. Dell Latitude D620 Keyboard Replacement: step 6, image 1 of 2 Dell Latitude D620 Keyboard Replacement: step 6, image 2 of 2
      • Using a small spudger, pull back on the black bar to release the blue lever
      Ask FixBot
    7. Dell Latitude D620 Keyboard Replacement: step 7, image 1 of 1
      • Pull up on the metal bar connected to the socket to detach the ribbon cable
      Ask FixBot
11 other people completed this guide.
Miguel Wong
565 Reputation
3 Guides authored
Cal Poly, Team 24-35, Regan Spring 2010 Member of Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Members
48 Guides authored
1 Guide Comment
Check out this keyboard at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 118
All Time: 17,665
