Dell Latitude D620 Display Replacement
    1. Dell Latitude D620 Display Replacement, Keyboard: step 1, image 1 of 1
      • Power down the laptop and remove the battery.
      • Open the laptop cover all of the way.
      Ask FixBot
    2. Dell Latitude D620 Display Replacement: step 2, image 1 of 3 Dell Latitude D620 Display Replacement: step 2, image 2 of 3 Dell Latitude D620 Display Replacement: step 2, image 3 of 3
      • Locate the notch under the cover at the top of the keyboard
      • Using the spudger as a lever, lift the plastic covering
      • Carefully remove the rest of the covering from right to left
      Ask FixBot
    3. Dell Latitude D620 Display Replacement: step 3, image 1 of 1
      • Unscrew the top portion of the keyboard using a #00 screwdriver
      Ask FixBot
    4. Dell Latitude D620 Display Replacement: step 4, image 1 of 1
      • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
      • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
      Ask FixBot
    5. Dell Latitude D620 Display Replacement: step 5, image 1 of 2 Dell Latitude D620 Display Replacement: step 5, image 2 of 2
      • Once keyboard is out of the case, lay it face-down on the track pad
      Ask FixBot
    6. Dell Latitude D620 Display Replacement: step 6, image 1 of 2 Dell Latitude D620 Display Replacement: step 6, image 2 of 2
      • Using a small spudger, pull back on the black bar to release the blue lever
      Ask FixBot
    7. Dell Latitude D620 Display Replacement: step 7, image 1 of 1
      • Pull up on the metal bar connected to the socket to detach the ribbon cable
      Ask FixBot
    1. Dell Latitude D620 Display Replacement, Display: step 8, image 1 of 1
      • Detach cables that connect the display to the body of the laptop
      Ask FixBot
    2. Dell Latitude D620 Display Replacement: step 9, image 1 of 1
      • Disconnect the black cable attached to the motherboard
      Ask FixBot
    3. Dell Latitude D620 Display Replacement: step 10, image 1 of 2 Dell Latitude D620 Display Replacement: step 10, image 2 of 2
      • Close the laptop lid
      • Turn the laptop over onto its backside
      • Unscrew the two screws shown in the picture using a #00 screwdriver
      Ask FixBot
    4. Dell Latitude D620 Display Replacement: step 11, image 1 of 2 Dell Latitude D620 Display Replacement: step 11, image 2 of 2
      • Face the laptop's back ports towards you
      • Unscrew the two screws labeled in the picture using a #00 screwdriver
      Ask FixBot
    5. Dell Latitude D620 Display Replacement: step 12, image 1 of 1
      • Turn the laptop over again so it's right-side up
      • Open the display, and pull the display up and out of the laptop's body
      Ask FixBot
    6. Dell Latitude D620 Display Replacement: step 13, image 1 of 1
      • Remove the circular rubber pads as outlined in the picture using a spudger
      Ask FixBot
    7. Dell Latitude D620 Display Replacement: step 14, image 1 of 1
      • Unscrew the screws that were under the rubber circles using the #00 screwdriver
      Ask FixBot
    8. Dell Latitude D620 Display Replacement: step 15, image 1 of 1
      • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
      • Be very careful while doing this as the plastic snaps easily
      Ask FixBot
    9. Dell Latitude D620 Display Replacement: step 16, image 1 of 1
      • Remove the screws outlined in the picture
      Ask FixBot
    10. Dell Latitude D620 Display Replacement: step 17, image 1 of 1
      • Carefully lift the LCD screen out of its casing
      Ask FixBot
19 other people completed this guide.
Miguel Wong
565 Reputation
3 Guides authored
Cal Poly, Team 24-35, Regan Spring 2010 Member of Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Members
48 Guides authored
1 Guide Comment
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 103
All Time: 34,138
