Dell Latitude D620 CD Drive Replacement
    1. Dell Latitude D620 CD Drive Replacement, Keyboard: step 1, image 1 of 1
      • Power down the laptop and remove the battery.
      • Open the laptop cover all of the way.
      Ask FixBot
    2. Dell Latitude D620 CD Drive Replacement: step 2, image 1 of 3 Dell Latitude D620 CD Drive Replacement: step 2, image 2 of 3 Dell Latitude D620 CD Drive Replacement: step 2, image 3 of 3
      • Locate the notch under the cover at the top of the keyboard
      • Using the spudger as a lever, lift the plastic covering
      • Carefully remove the rest of the covering from right to left
      Ask FixBot
    3. Dell Latitude D620 CD Drive Replacement: step 3, image 1 of 1
      • Unscrew the top portion of the keyboard using a #00 screwdriver
      Ask FixBot
    4. Dell Latitude D620 CD Drive Replacement: step 4, image 1 of 1
      • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
      • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
      Ask FixBot
    5. Dell Latitude D620 CD Drive Replacement: step 5, image 1 of 2 Dell Latitude D620 CD Drive Replacement: step 5, image 2 of 2
      • Once keyboard is out of the case, lay it face-down on the track pad
      Ask FixBot
    6. Dell Latitude D620 CD Drive Replacement: step 6, image 1 of 2 Dell Latitude D620 CD Drive Replacement: step 6, image 2 of 2
      • Using a small spudger, pull back on the black bar to release the blue lever
      Ask FixBot
    7. Dell Latitude D620 CD Drive Replacement: step 7, image 1 of 1
      • Pull up on the metal bar connected to the socket to detach the ribbon cable
      Ask FixBot
    1. Dell Latitude D620 CD Drive Replacement, CD Drive: step 8, image 1 of 2 Dell Latitude D620 CD Drive Replacement, CD Drive: step 8, image 2 of 2
      • Press in the tab on the bottom right side of the CD drive
      • The tab comes out on its own; there is no need to pull it out manually.
      Ask FixBot
    2. Dell Latitude D620 CD Drive Replacement: step 9, image 1 of 1
      • Gently pull the tab to remove the disk tray.
      Ask FixBot
10 other people completed this guide.
Ivan
203 Reputation
1 Guide authored
Cal Poly, Team 24-35, Regan Spring 2010 Member of Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 110
All Time: 9,238
