Up to 20% off select tools
Dell Latitude D610 RAM Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
102
All Time:
2,614
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Parts
Tools
Introduction
Go to step 1 ↓
Replacing a defective RAM component is pretty easy and can stop your computer from frequently crashing.
    1. Dell Latitude D610 RAM Replacement, Battery: step 1, image 1 of 2 Dell Latitude D610 RAM Replacement, Battery: step 1, image 2 of 2
      • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
      Ask FixBot
    2. Dell Latitude D610 RAM Replacement: step 2, image 1 of 3 Dell Latitude D610 RAM Replacement: step 2, image 2 of 3 Dell Latitude D610 RAM Replacement: step 2, image 3 of 3
      • Locate the laptop battery release button lock
      • Push the battery release in the direction of the arrow, and pull upward.
      Ask FixBot
    3. Dell Latitude D610 RAM Replacement: step 3, image 1 of 1
      • Remove the battery from its compartment.
      Ask FixBot
    1. Dell Latitude D610 RAM Replacement, RAM: step 4, image 1 of 3 Dell Latitude D610 RAM Replacement, RAM: step 4, image 2 of 3 Dell Latitude D610 RAM Replacement, RAM: step 4, image 3 of 3
      • Remove the 3.9mm Philips #1 screw holding the panel for the RAM.
      Ask FixBot
    2. Dell Latitude D610 RAM Replacement: step 5, image 1 of 2 Dell Latitude D610 RAM Replacement: step 5, image 2 of 2
      • Lift and remove the panel.
      Ask FixBot
    3. Dell Latitude D610 RAM Replacement: step 6, image 1 of 3 Dell Latitude D610 RAM Replacement: step 6, image 2 of 3 Dell Latitude D610 RAM Replacement: step 6, image 3 of 3
      • Using two fingers, push the silver ends away from the RAM until the RAM is released.
      Ask FixBot
    4. Dell Latitude D610 RAM Replacement: step 7, image 1 of 3 Dell Latitude D610 RAM Replacement: step 7, image 2 of 3 Dell Latitude D610 RAM Replacement: step 7, image 3 of 3
      • Lift the RAM from its slot.
      • Remove the RAM completely.
      Ask FixBot
6 other people completed this guide.
Author
with
Jordan Barham
459 Reputation
3 Guides authored
Cal Poly, Team 6-24, Maness Winter 2014 Member of Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Members
60 Guides authored
1 Guide Comment
This model has two RAM slots. The second one is under the keypad. Carefully remove the bezel at the top of the keypad, remove the two screws holding the keypad down, then remove the keypad to expose the second slot. This RAM slot is a little bit more difficult to get to than the one on the back of the laptop, but is still very easy to access and change out.
Chris Kelley - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 102
All Time: 2,614
