Dell Latitude D610 Modem Replacement
    1. Dell Latitude D610 Modem Replacement, Battery: step 1, image 1 of 2 Dell Latitude D610 Modem Replacement, Battery: step 1, image 2 of 2
      • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
      Ask FixBot
    2. Dell Latitude D610 Modem Replacement: step 2, image 1 of 3 Dell Latitude D610 Modem Replacement: step 2, image 2 of 3 Dell Latitude D610 Modem Replacement: step 2, image 3 of 3
      • Locate the laptop battery release button lock
      • Push the battery release in the direction of the arrow, and pull upward.
      Ask FixBot
    3. Dell Latitude D610 Modem Replacement: step 3, image 1 of 1
      • Remove the battery from its compartment.
      Ask FixBot
    1. Dell Latitude D610 Modem Replacement, Modem: step 4, image 1 of 3 Dell Latitude D610 Modem Replacement, Modem: step 4, image 2 of 3 Dell Latitude D610 Modem Replacement, Modem: step 4, image 3 of 3
      • Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
      Ask FixBot
    2. Dell Latitude D610 Modem Replacement: step 5, image 1 of 2 Dell Latitude D610 Modem Replacement: step 5, image 2 of 2
      • Lift and remove the lid.
      Ask FixBot
    3. Dell Latitude D610 Modem Replacement: step 6, image 1 of 2 Dell Latitude D610 Modem Replacement: step 6, image 2 of 2
      • Remove the 3.9mm Philips #1 screw on top of the modem.
      Ask FixBot
    4. Dell Latitude D610 Modem Replacement: step 7, image 1 of 3 Dell Latitude D610 Modem Replacement: step 7, image 2 of 3 Dell Latitude D610 Modem Replacement: step 7, image 3 of 3
      • Pull on the white tab to remove the modem
      • Remove the cable going to the modem.
      Ask FixBot
2 other people completed this guide.
Jose Chavez
122 Reputation
1 Guide authored
Cal Poly, Team 6-24, Maness Winter 2014 Member of Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Members
60 Guides authored
1 Guide Comment
I have manufacturing mode problem can you help me??
Mod - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 106
All Time: 2,223
