Dell Latitude D610 Keyboard Replacement
    1. Dell Latitude D610 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Latitude D610 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
      Ask FixBot
    2. Dell Latitude D610 Keyboard Replacement: step 2, image 1 of 3 Dell Latitude D610 Keyboard Replacement: step 2, image 2 of 3 Dell Latitude D610 Keyboard Replacement: step 2, image 3 of 3
      • Locate the laptop battery release button lock
      • Push the battery release in the direction of the arrow, and pull upward.
      Ask FixBot
    3. Dell Latitude D610 Keyboard Replacement: step 3, image 1 of 1
      • Remove the battery from its compartment.
      Ask FixBot
    1. Dell Latitude D610 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Dell Latitude D610 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Dell Latitude D610 Keyboard Replacement, Keyboard: step 4, image 3 of 3
      • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
      Ask FixBot
    2. Dell Latitude D610 Keyboard Replacement: step 5, image 1 of 2 Dell Latitude D610 Keyboard Replacement: step 5, image 2 of 2
      • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
      Ask FixBot
    3. Dell Latitude D610 Keyboard Replacement: step 6, image 1 of 2 Dell Latitude D610 Keyboard Replacement: step 6, image 2 of 2
      • Using an opening tool, carefully release the keyboard from the case.
      • Making sure not to tear or damage the wires still connecting it to the laptop.
      Ask FixBot
    4. Dell Latitude D610 Keyboard Replacement: step 7, image 1 of 3 Dell Latitude D610 Keyboard Replacement: step 7, image 2 of 3 Dell Latitude D610 Keyboard Replacement: step 7, image 3 of 3
      • Carfully lift the key board.
      • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
      • Pull on the blue tab to unplug the keyboard.
      Ask FixBot
4 other people completed this guide.
Jordan Barham
459 Reputation
3 Guides authored
Cal Poly, Team 6-24, Maness Winter 2014 Member of Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 103
All Time: 2,711
