Dell Latitude D610 Battery Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
93
All Time:
3,318
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Replacing a defective battery is pretty easy and will increase the time your computer will last after charging.
Tools
    1. Dell Latitude D610 Battery Replacement, Battery: step 1, image 1 of 2 Dell Latitude D610 Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
      Ask FixBot
    2. Dell Latitude D610 Battery Replacement: step 2, image 1 of 3 Dell Latitude D610 Battery Replacement: step 2, image 2 of 3 Dell Latitude D610 Battery Replacement: step 2, image 3 of 3
      • Locate the laptop battery release button lock
      • Push the battery release in the direction of the arrow, and pull upward.
      Ask FixBot
    3. Dell Latitude D610 Battery Replacement: step 3, image 1 of 1
      • Remove the battery from its compartment.
      Ask FixBot
5 other people completed this guide.
Cinthya
583 Reputation
1 Guide authored
Cal Poly, Team 6-24, Maness Winter 2014 Member of Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 93
All Time: 3,318
