Dell Latitude D600 Thermal Paste Replacement
    1. Dell Latitude D600 Thermal Paste Replacement, Opening the laptop.: step 1, image 1 of 3 Dell Latitude D600 Thermal Paste Replacement, Opening the laptop.: step 1, image 2 of 3 Dell Latitude D600 Thermal Paste Replacement, Opening the laptop.: step 1, image 3 of 3
      • Use a prying tool to remove the top panel.
      • This will reveal 2 screws that hold the keyboard in place, remove them.
      • After that - carefully unplug the keyboard and set it aside.
      Ask FixBot
    2. Dell Latitude D600 Thermal Paste Replacement, Cleaning the old thermal paste.: step 2, image 1 of 3 Dell Latitude D600 Thermal Paste Replacement, Cleaning the old thermal paste.: step 2, image 2 of 3 Dell Latitude D600 Thermal Paste Replacement, Cleaning the old thermal paste.: step 2, image 3 of 3
      • Unscrew the 4 screws that hold the CPU heatsink in place.
      • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
      Ask FixBot
    3. Dell Latitude D600 Thermal Paste Replacement, Applying new thermal paste.: step 3, image 1 of 1
      • Don`t use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
      • Put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure.
      Ask FixBot
Simeon Brankov
10,409 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 33
All Time: 411
