Up to 20% off select tools
Dell Latitude CS RAM Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
78
All Time:
2,824
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Not much prior knowledge is required before starting. According to Dell, however, you must have the following tools:
"‡#0 and #1 magnetized Phillips-head screwdrivers
‡ Small flat-blade screwdriver
‡ 5-mm socket wrench
‡ 7-mm socket wrench
‡ Small plastic scribe"
(Guide found at: Dell Latitude CS Portable Computers Service Manual)
    1. Dell Latitude CS RAM Replacement, RAM: step 1, image 1 of 2 Dell Latitude CS RAM Replacement, RAM: step 1, image 2 of 2
      • Flip laptop over.
      Ask FixBot
    2. Dell Latitude CS RAM Replacement: step 2, image 1 of 2 Dell Latitude CS RAM Replacement: step 2, image 2 of 2
      • Remove the screws over the RAM door
      Ask FixBot
    3. Dell Latitude CS RAM Replacement: step 3, image 1 of 2 Dell Latitude CS RAM Replacement: step 3, image 2 of 2
      • Open the RAM door.
      Ask FixBot
    4. Dell Latitude CS RAM Replacement: step 4, image 1 of 2 Dell Latitude CS RAM Replacement: step 4, image 2 of 2
      • Carefully pull the tabs over the RAM chip down - the RAM will spring up.
      Ask FixBot
    5. Dell Latitude CS RAM Replacement: step 5, image 1 of 1
      • Remove the RAM from the socket and insert replacement RAM.
      Ask FixBot
3 other people completed this guide.
Author
with
Axuak
331 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 78
All Time: 2,824
