Up to 20% off select tools
Dell Latitude 7490 RAM Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
30
Past 30 Days:
135
All Time:
3,431
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace or upgrade the RAM in your Dell Latitude 7490 laptop.
This laptop has two SO-DIMM slots that support DDR4 memory modules.
    1. Dell Latitude 7490 RAM Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Dell Latitude 7490 RAM Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Dell Latitude 7490 RAM Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet strips are facing up.
      Ask FixBot
    2. Dell Latitude 7490 RAM Replacement, Loosen the captive screws: step 3, image 1 of 2 Dell Latitude 7490 RAM Replacement, Loosen the captive screws: step 3, image 2 of 2
      • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
      Ask FixBot
    3. Dell Latitude 7490 RAM Replacement, Insert an opening pick: step 4, image 1 of 3 Dell Latitude 7490 RAM Replacement, Insert an opening pick: step 4, image 2 of 3 Dell Latitude 7490 RAM Replacement, Insert an opening pick: step 4, image 3 of 3
      • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
      • Insert the long side of an opening pick between the top right corner of the back cover and frame.
      • Pry the back cover up to release the clips securing the top right corner.
      Ask FixBot
    4. Dell Latitude 7490 RAM Replacement, Release the clips: step 5, image 1 of 3 Dell Latitude 7490 RAM Replacement, Release the clips: step 5, image 2 of 3 Dell Latitude 7490 RAM Replacement, Release the clips: step 5, image 3 of 3
      • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
      Ask FixBot
    5. Dell Latitude 7490 RAM Replacement: step 6, image 1 of 3 Dell Latitude 7490 RAM Replacement: step 6, image 2 of 3 Dell Latitude 7490 RAM Replacement: step 6, image 3 of 3
      • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
      Ask FixBot
    6. Dell Latitude 7490 RAM Replacement, Remove the back cover: step 7, image 1 of 3 Dell Latitude 7490 RAM Replacement, Remove the back cover: step 7, image 2 of 3 Dell Latitude 7490 RAM Replacement, Remove the back cover: step 7, image 3 of 3
      • Remove the back cover.
      • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
      Ask FixBot
    1. Dell Latitude 7490 RAM Replacement, Disconnect the battery: step 8, image 1 of 2 Dell Latitude 7490 RAM Replacement, Disconnect the battery: step 8, image 2 of 2
      • Grip the plastic tab on the battery connector and pull straight up to disconnect it.
      • During reassembly, align this connector over its socket and press down until it clicks into place. If it doesn't connect, re‑align it and try again.
      Ask FixBot
    1. Dell Latitude 7490 RAM Replacement, Remove the RAM: step 9, image 1 of 3 Dell Latitude 7490 RAM Replacement, Remove the RAM: step 9, image 2 of 3 Dell Latitude 7490 RAM Replacement, Remove the RAM: step 9, image 3 of 3
      • Two metal arms secure the left and right edges of each RAM module.
      • Simultaneously push the arms outward to disengage them.
      • The module should pop up at a slight angle.
      • Remove the RAM module.
      • Repeat the process for the second RAM module.
      • To install a RAM module, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the module in place.
      Ask FixBot
Spencer Day
210,928 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 135
All Time: 3,431
