Dell Latitude 7490 Battery Replacement
Views: 11K
View statistics:
Past 24 Hours:
10
Past 7 Days:
73
Past 30 Days:
311
All Time:
11,215
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a dead or malfunctioning battery in your Dell Latitude 4790 laptop.
If your battery is swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Dell Latitude 7490 Battery Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Dell Latitude 7490 Battery Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Dell Latitude 7490 Battery Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet strips are facing up.
      Ask FixBot
    2. Dell Latitude 7490 Battery Replacement, Loosen the captive screws: step 3, image 1 of 2 Dell Latitude 7490 Battery Replacement, Loosen the captive screws: step 3, image 2 of 2
      • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
      Ask FixBot
    3. Dell Latitude 7490 Battery Replacement, Insert an opening pick: step 4, image 1 of 3 Dell Latitude 7490 Battery Replacement, Insert an opening pick: step 4, image 2 of 3 Dell Latitude 7490 Battery Replacement, Insert an opening pick: step 4, image 3 of 3
      • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
      • Insert the long side of an opening pick between the top right corner of the back cover and frame.
      • Pry the back cover up to release the clips securing the top right corner.
      Ask FixBot
    4. Dell Latitude 7490 Battery Replacement, Release the clips: step 5, image 1 of 3 Dell Latitude 7490 Battery Replacement, Release the clips: step 5, image 2 of 3 Dell Latitude 7490 Battery Replacement, Release the clips: step 5, image 3 of 3
      • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
      Ask FixBot
    5. Dell Latitude 7490 Battery Replacement: step 6, image 1 of 3 Dell Latitude 7490 Battery Replacement: step 6, image 2 of 3 Dell Latitude 7490 Battery Replacement: step 6, image 3 of 3
      • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
      Ask FixBot
    6. Dell Latitude 7490 Battery Replacement, Remove the back cover: step 7, image 1 of 3 Dell Latitude 7490 Battery Replacement, Remove the back cover: step 7, image 2 of 3 Dell Latitude 7490 Battery Replacement, Remove the back cover: step 7, image 3 of 3
      • Remove the back cover.
      • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
      Ask FixBot
    1. Dell Latitude 7490 Battery Replacement, Disconnect the battery: step 8, image 1 of 2 Dell Latitude 7490 Battery Replacement, Disconnect the battery: step 8, image 2 of 2
      • Grip the plastic tab on the battery connector and pull straight up to disconnect it.
      • During reassembly, align this connector over its socket and press down until it clicks into place. If it doesn't connect, re‑align it and try again.
      Ask FixBot
    1. Dell Latitude 7490 Battery Replacement, Unfasten the battery: step 9, image 1 of 2 Dell Latitude 7490 Battery Replacement, Unfasten the battery: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two 5.7 mm‑long screws securing the battery.
      Ask FixBot
    2. Dell Latitude 7490 Battery Replacement, Remove the battery: step 10, image 1 of 3 Dell Latitude 7490 Battery Replacement, Remove the battery: step 10, image 2 of 3 Dell Latitude 7490 Battery Replacement, Remove the battery: step 10, image 3 of 3
      • Lift the top edge of the battery.
      • Slide the battery's bottom edge out of its recess in the frame and remove the battery.
      Ask FixBot
    3. Dell Latitude 7490 Battery Replacement, Reassembly information: step 11, image 1 of 3 Dell Latitude 7490 Battery Replacement, Reassembly information: step 11, image 2 of 3 Dell Latitude 7490 Battery Replacement, Reassembly information: step 11, image 3 of 3
      • During reassembly, slide the four plastic tabs on the bottom edge of the battery into their recesses on the frame before securing the battery.
      Ask FixBot
    4. Dell Latitude 7490 Battery Replacement, Remove the battery cable: step 12, image 1 of 3 Dell Latitude 7490 Battery Replacement, Remove the battery cable: step 12, image 2 of 3 Dell Latitude 7490 Battery Replacement, Remove the battery cable: step 12, image 3 of 3
      • If your replacement battery doesn’t come with a cable preinstalled, you’ll have to transfer your original cable to the new battery.
      • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
      • Flip the battery over and lay it on a clean working surface.
      • Use one hand to secure the battery.
      • Use your other hand to firmly pull the battery connector out of its socket on the bottom edge of the battery.
      • Remove the battery cable from its recess between the two battery cells.
      • During reassembly, transfer the battery cable to your new battery, making sure the cable is snug between the battery cells.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
13 other people completed this guide.
Spencer Day
206,591 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
1 Guide Comment
This was super helpful Spencer. Unfortunately, I'm having one pesky problem with my Dell after having installed the new battery. I pulled out the AC adapter to drain the battery down to zero (after my first full charge, any my laptop just shut right off.) I did a modern Gemini Search based on the fact that I had just swapped out my battery for my Dell Latitude 7490. Any suggestions beyond what I've go here?
https://docs.google.com/document/d/1RN-S...
Ethan L - Reply Share
Past 24 Hours: 10
Past 7 Days: 73
Past 30 Days: 311
All Time: 11,215
