Dell Latitude 7490 Back Cover Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
87
All Time:
2,069
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove or replace the back cover on your Dell Latitude 7490 laptop.
Tools
    1. Dell Latitude 7490 Back Cover Replacement, Flip your laptop over: step 1, image 1 of 1
      • Flip your laptop over so the rubber feet strips are facing up.
      Ask FixBot
    2. Dell Latitude 7490 Back Cover Replacement, Loosen the captive screws: step 2, image 1 of 2 Dell Latitude 7490 Back Cover Replacement, Loosen the captive screws: step 2, image 2 of 2
      • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
      Ask FixBot
    3. Dell Latitude 7490 Back Cover Replacement, Insert an opening pick: step 3, image 1 of 3 Dell Latitude 7490 Back Cover Replacement, Insert an opening pick: step 3, image 2 of 3 Dell Latitude 7490 Back Cover Replacement, Insert an opening pick: step 3, image 3 of 3
      • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
      • Insert the long side of an opening pick between the top right corner of the back cover and frame.
      • Pry the back cover up to release the clips securing the top right corner.
      Ask FixBot
    4. Dell Latitude 7490 Back Cover Replacement, Release the clips: step 4, image 1 of 3 Dell Latitude 7490 Back Cover Replacement, Release the clips: step 4, image 2 of 3 Dell Latitude 7490 Back Cover Replacement, Release the clips: step 4, image 3 of 3
      • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
      Ask FixBot
    5. Dell Latitude 7490 Back Cover Replacement: step 5, image 1 of 3 Dell Latitude 7490 Back Cover Replacement: step 5, image 2 of 3 Dell Latitude 7490 Back Cover Replacement: step 5, image 3 of 3
      • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
      Ask FixBot
    6. Dell Latitude 7490 Back Cover Replacement, Remove the back cover: step 6, image 1 of 3 Dell Latitude 7490 Back Cover Replacement, Remove the back cover: step 6, image 2 of 3 Dell Latitude 7490 Back Cover Replacement, Remove the back cover: step 6, image 3 of 3
      • Remove the back cover.
      • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
      Ask FixBot
Spencer Day
206,507 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 87
All Time: 2,069
