Dell Latitude 7420 SSD Replacement
    1. Dell Latitude 7420 SSD Replacement, Back Case: step 1, image 1 of 3 Dell Latitude 7420 SSD Replacement, Back Case: step 1, image 2 of 3 Dell Latitude 7420 SSD Replacement, Back Case: step 1, image 3 of 3
      • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
      • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
      Ask FixBot
    1. Dell Latitude 7420 SSD Replacement, SSD: step 2, image 1 of 3 Dell Latitude 7420 SSD Replacement, SSD: step 2, image 2 of 3 Dell Latitude 7420 SSD Replacement, SSD: step 2, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the two 2.0 mm screws holding down the SSD cover.
      • Remove the SSD cover.
      • Notice that the left screw is also pinning the SSD card in place.
      Ask FixBot
    2. Dell Latitude 7420 SSD Replacement: step 3, image 1 of 1
      • Pull the SSD card by its left edge to slide it out of the socket.
      Ask FixBot
3 other people completed this guide.
Nick B.
761 Reputation
4 Guides authored
Gateway, Team 1-2, Pee Spring 2023 Member of Gateway, Team 1-2, Pee Spring 2023
GCC-PEE-S23S1G2
4 Members
72 Guides authored
4 Guide Comments
Thanks this helped out alot
Anna Cruz - Reply Share
Can I put the SSD cover back on after installing the SSD? It appears to have some paste on it, assuming it's for cooling?
Emily - Reply Share
This is the ONLY internal storage on this laptop, right? So we need to make a Windows backup before starting?
Laura Doan - Reply Share
Yes it is the ONLY storage in the device. You definitely need a Windows backup. Alternatively you can reinstall Windows completely new.
Daniel Kramp - Reply Share
Past 24 Hours: 8
Past 7 Days: 64
Past 30 Days: 250
All Time: 8,047
