Dell Latitude 7420 Fan Assembly Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
8
Past 7 Days:
78
Past 30 Days:
275
All Time:
5,136
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 - 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your laptop keeps overheating, you may need to replace the fans and heat sink. Your Dell Latitude 7420 laptop may overheat due to dirty or dusty vents or fans. This can often be fixed by cleaning out the vents or fan with a dust blower. If that doesn't fix the issue, checking the thermal paste under the heat sink is a good idea because it may need to be replaced too.
Before starting, please ensure the device is turned off and disconnected from any adaptors or charging cables.
Likewise, use an anti-static band or mat when opening computers or handling components.
If the thermal paste in the Dell Latitude 7420 needs to be replaced, an in-depth application guide can be found here.
Parts
Tools
    1. Dell Latitude 7420 Fan Assembly Replacement, Back Case: step 1, image 1 of 3 Dell Latitude 7420 Fan Assembly Replacement, Back Case: step 1, image 2 of 3 Dell Latitude 7420 Fan Assembly Replacement, Back Case: step 1, image 3 of 3
      • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
      • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
      Ask FixBot
    1. Dell Latitude 7420 Fan Assembly Replacement, Battery: step 2, image 1 of 2 Dell Latitude 7420 Fan Assembly Replacement, Battery: step 2, image 2 of 2
      • Be sure to use an anti-static band or mat from this point onward.
      • Using the Phillips #1 screwdriver, remove the five 5 mm screws securing the battery to the motherboard.
      Ask FixBot
    2. Dell Latitude 7420 Fan Assembly Replacement: step 3, image 1 of 2 Dell Latitude 7420 Fan Assembly Replacement: step 3, image 2 of 2
      • Use a spudger to pry up each side of the battery connector. Then, lift the connector straight up from its socket.
      • To reinstall, carefully position the connector, and then press it straight down until it snaps into its socket. Finger pressure is all that is required. If it won't snap home it'll be because it isn't correctly positioned. Sometimes it can take a little patience to find exactly the right position.
      Ask FixBot
    3. Dell Latitude 7420 Fan Assembly Replacement: step 4, image 1 of 2 Dell Latitude 7420 Fan Assembly Replacement: step 4, image 2 of 2
      • Unplug the speaker cable by pulling it down, then carefully unthread the cable from the battery
      Ask FixBot
    4. Dell Latitude 7420 Fan Assembly Replacement: step 5, image 1 of 1
      • Gently remove the battery from its housing.
      Ask FixBot
    1. Dell Latitude 7420 Fan Assembly Replacement, Fan Assembly: step 6, image 1 of 2 Dell Latitude 7420 Fan Assembly Replacement, Fan Assembly: step 6, image 2 of 2
      Tool used on this step:
      Dust Blower
      $5.99
      Buy
      • Keeping the vents on the case of the laptop clean of dust or debris and clear of obstruction is important for the device to maintain its temperature.
      • Use a cloth and dust blower to clean the vents.
      • It's best to clean the vent when the back case has been removed from the device.
      Ask FixBot
    2. Dell Latitude 7420 Fan Assembly Replacement: step 7, image 1 of 3 Dell Latitude 7420 Fan Assembly Replacement: step 7, image 2 of 3 Dell Latitude 7420 Fan Assembly Replacement: step 7, image 3 of 3
      • If the fan is dusty, a soft cloth can be used to gently clean it.
      • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the fan assembly.
      Ask FixBot
    3. Dell Latitude 7420 Fan Assembly Replacement: step 8, image 1 of 3 Dell Latitude 7420 Fan Assembly Replacement: step 8, image 2 of 3 Dell Latitude 7420 Fan Assembly Replacement: step 8, image 3 of 3
      • Use the pointed tip of a spudger to carefully push on each side of the connector and remove it from the socket.
      • Remove the fan assembly.
      • When replacing the fan assembly, make sure there is thermal paste under the heat sink. Follow this guide for more information.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 other people completed this guide.
Nick B.
761 Reputation
4 Guides authored
Gateway, Team 1-2, Pee Spring 2023 Member of Gateway, Team 1-2, Pee Spring 2023
GCC-PEE-S23S1G2
4 Members
72 Guides authored
5 Guide Comments
Hi. Is it possibel to replace the fan only?
I ordered some fan part from amazon which looks identical but the fan is attached to the heartsink element and its not clear how to detach it.
MAS - Reply Share
@mustaffaab64308 Usually fans are glued ore taped to heatsinks. There may be a model where it is screwed to it but thats rather rare. If you look online, you find nothing about detaching the fan from the heatsink. Is it possible that you ordered a fan for the Inspiron 7420 ? In that model, you can detach it easily.
Daniel Kramp - Reply Share
@olli_wuff Thanks for your follow up. The Fan I ordered was a standalone part (without the heatsink). I was about to return the fan but then found the very small screws under this foam, which allows you to detach the fan from the heatsink and replace the fan only :)
And, yes. there is absolutely nothing on the internet or AI about that, so I guess I made a worlds-first discovery? :D
MAS - Reply Share
@mustaffaab64308 Very Cool! Congratulations for your succesfull repair!
@mustaffaab64308 yes it is possible to change only the fan - I can confirm what @olli_wuff said: there are screws under the foam, there are three screws. you actually don't need to do any other step besides take the back off: find the three screws under the foam, and the two screws on the left that aren't covered by foam, then disconnect the fan power and gently lift the fan assembly (which is connected to the heat sink) about 2 cm or 0.5 inch. when you lift it, you can slide out the fan itself and slide in your new replacement part which is around $15.
Olei Ziak - Reply Share
Past 24 Hours: 8
Past 7 Days: 78
Past 30 Days: 275
All Time: 5,136
