Dell Latitude 7420 Display Replacement
    1. Dell Latitude 7420 Display Replacement, Back Case: step 1, image 1 of 3 Dell Latitude 7420 Display Replacement, Back Case: step 1, image 2 of 3 Dell Latitude 7420 Display Replacement, Back Case: step 1, image 3 of 3
      • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
      • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
      Ask FixBot
    1. Dell Latitude 7420 Display Replacement, Display: step 2, image 1 of 3 Dell Latitude 7420 Display Replacement, Display: step 2, image 2 of 3 Dell Latitude 7420 Display Replacement, Display: step 2, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the three, 2 mm screws fastening the cable covers.
      • Remove both cable covers.
      Ask FixBot
    2. Dell Latitude 7420 Display Replacement: step 3, image 1 of 2 Dell Latitude 7420 Display Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to detach the coaxial cables from the Wi-Fi card.
      • Disconnect the remaining cables connecting the display assembly to the board.
      Ask FixBot
    3. Dell Latitude 7420 Display Replacement: step 4, image 1 of 3 Dell Latitude 7420 Display Replacement: step 4, image 2 of 3 Dell Latitude 7420 Display Replacement: step 4, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four 4 mm screws securing the display hinges.
      • There are two screws to remove from each hinge.
      • Lift the base to pull the display assembly free.
      Ask FixBot
    4. Dell Latitude 7420 Display Replacement: step 5, image 1 of 1
      • Separate the display assembly from the base of the laptop.
      Ask FixBot
nuredinroba
209 Reputation
1 Guide authored
Gateway, Team 1-2, Pee Spring 2023 Member of Gateway, Team 1-2, Pee Spring 2023
GCC-PEE-S23S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 156
All Time: 3,626
