Dell Latitude 7420 Battery Replacement
    1. Dell Latitude 7420 Battery Replacement, Back Case: step 1, image 1 of 3 Dell Latitude 7420 Battery Replacement, Back Case: step 1, image 2 of 3 Dell Latitude 7420 Battery Replacement, Back Case: step 1, image 3 of 3
      • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
      • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
      Ask FixBot
    1. Dell Latitude 7420 Battery Replacement, Battery: step 2, image 1 of 2 Dell Latitude 7420 Battery Replacement, Battery: step 2, image 2 of 2
      • Be sure to use an anti-static band or mat from this point onward.
      • Using the Phillips #1 screwdriver, remove the five 5 mm screws securing the battery to the motherboard.
      Ask FixBot
    2. Dell Latitude 7420 Battery Replacement: step 3, image 1 of 2 Dell Latitude 7420 Battery Replacement: step 3, image 2 of 2
      • Use a spudger to pry up each side of the battery connector. Then, lift the connector straight up from its socket.
      • To reinstall, carefully position the connector, and then press it straight down until it snaps into its socket. Finger pressure is all that is required. If it won't snap home it'll be because it isn't correctly positioned. Sometimes it can take a little patience to find exactly the right position.
      Ask FixBot
    3. Dell Latitude 7420 Battery Replacement: step 4, image 1 of 2 Dell Latitude 7420 Battery Replacement: step 4, image 2 of 2
      • Unplug the speaker cable by pulling it down, then carefully unthread the cable from the battery
      Ask FixBot
    4. Dell Latitude 7420 Battery Replacement: step 5, image 1 of 1
      • Gently remove the battery from its housing.
      Ask FixBot
3 other people completed this guide.
Xaiven Watson-torres
124 Reputation
1 Guide authored
Gateway, Team 1-2, Pee Spring 2023 Member of Gateway, Team 1-2, Pee Spring 2023
GCC-PEE-S23S1G2
4 Members
72 Guides authored
2 Guide Comments
i was looking for battery to buy is this correct "https://ar.aliexpress.com/item/100500882...
mohssen boulahbal - Reply Share
Unfortunately your link cannot be openend. The item isn't availabe anymore.
Daniel Kramp - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 167
All Time: 3,442
