Dell Latitude 7420 Battery Replacement
  1. Dell Latitude 7420 Battery Replacement, Battery: step 1, image 1 of 2 Dell Latitude 7420 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
    Ask FixBot
  2. Dell Latitude 7420 Battery Replacement: step 2, image 1 of 2 Dell Latitude 7420 Battery Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
    Ask FixBot
  3. Dell Latitude 7420 Battery Replacement: step 3, image 1 of 2 Dell Latitude 7420 Battery Replacement: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
    Ask FixBot
  4. Dell Latitude 7420 Battery Replacement: step 4, image 1 of 1
    • Disconnect the battery from the motherboard by gently pulling out the connector.
    Ask FixBot
  5. Dell Latitude 7420 Battery Replacement: step 5, image 1 of 2 Dell Latitude 7420 Battery Replacement: step 5, image 2 of 2
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
    Ask FixBot
7 other people completed this guide.
Hong Lee
271 Reputation
1 Guide authored
3 Guide Comments
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - Reply Share
One thing to be aware of is that if you order a replacement battery from Dell, they do NOT include the cable that connects the battery to the mobo! You need to reuse your old battery cable (and hope it's not bad).
Anna - Reply Share
Only the top screw of the battery will really come completely loose. The other ones are attached and also present in the spare part.
Also, don't remove the connector on the board. Remove the one on the battery and attach it later to the new battery.
Sebastian - Reply Share
Past 24 Hours: 7
Past 7 Days: 58
Past 30 Days: 256
All Time: 18,631
