Dell Latitude 7410 SSD Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
7
Past 7 Days:
36
Past 30 Days:
132
All Time:
2,674
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to upgrade or replace the SSD in your Dell Latitude 7410 laptop.
Before you perform this repair, back up your existing SSD if possible. If you're replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD. There are many tools to do this, but this article is a good place to start, if you're unfamiliar with the process.
Tools
    1. Dell Latitude 7410 SSD Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      Ask FixBot
    1. Dell Latitude 7410 SSD Replacement, Unfasten the back cover: step 2, image 1 of 1
      • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
      Ask FixBot
    2. Dell Latitude 7410 SSD Replacement, Insert an opening pick: step 3, image 1 of 2 Dell Latitude 7410 SSD Replacement, Insert an opening pick: step 3, image 2 of 2
      • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
      Ask FixBot
    3. Dell Latitude 7410 SSD Replacement, Unclip the right edge: step 4, image 1 of 2 Dell Latitude 7410 SSD Replacement, Unclip the right edge: step 4, image 2 of 2
      • Slide your pick along the right edge to release the clips securing the back cover.
      Ask FixBot
    4. Dell Latitude 7410 SSD Replacement, Unclip the left edge: step 5, image 1 of 3 Dell Latitude 7410 SSD Replacement, Unclip the left edge: step 5, image 2 of 3 Dell Latitude 7410 SSD Replacement, Unclip the left edge: step 5, image 3 of 3
      • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
      • Slide your pick along the left edge to release the clips.
      Ask FixBot
    5. Dell Latitude 7410 SSD Replacement, Unclip the back edge: step 6, image 1 of 3 Dell Latitude 7410 SSD Replacement, Unclip the back edge: step 6, image 2 of 3 Dell Latitude 7410 SSD Replacement, Unclip the back edge: step 6, image 3 of 3
      • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
      • Slide your pick toward the left hinge until the second clip releases.
      Ask FixBot
    6. Dell Latitude 7410 SSD Replacement, Unclip the front edge: step 7, image 1 of 2 Dell Latitude 7410 SSD Replacement, Unclip the front edge: step 7, image 2 of 2
      • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
      • Slide your pick toward the right edge until the front edge releases from the frame.
      Ask FixBot
    7. Dell Latitude 7410 SSD Replacement, Remove the back cover: step 8, image 1 of 2 Dell Latitude 7410 SSD Replacement, Remove the back cover: step 8, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Dell Latitude 7410 SSD Replacement, Disconnect the battery: step 9, image 1 of 2 Dell Latitude 7410 SSD Replacement, Disconnect the battery: step 9, image 2 of 2
      • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
      Ask FixBot
    1. Dell Latitude 7410 SSD Replacement, Remove the SSD shield: step 10, image 1 of 3 Dell Latitude 7410 SSD Replacement, Remove the SSD shield: step 10, image 2 of 3 Dell Latitude 7410 SSD Replacement, Remove the SSD shield: step 10, image 3 of 3
      • Use your Phillips screwdriver to remove the 2.7 mm screw securing the SSD shield.
      • Grab and remove the SSD shield.
      Ask FixBot
    2. Dell Latitude 7410 SSD Replacement, Unfasten the SSD: step 11, image 1 of 1
      • Use your Phillips screwdriver to remove the 3 mm screw securing the SSD.
      Ask FixBot
    3. Dell Latitude 7410 SSD Replacement, Remove the SSD: step 12, image 1 of 3 Dell Latitude 7410 SSD Replacement, Remove the SSD: step 12, image 2 of 3 Dell Latitude 7410 SSD Replacement, Remove the SSD: step 12, image 3 of 3
      • The socket doesn't spring up the SSD like in some laptops—keep the SSD flat to the laptop when removing or inserting it to prevent damage to the socket.
      • Grip the corners of the SSD closest to the screw cutout and pull it straight out of its socket and remove it.
      • If the SSD feels stuck, slightly wiggle it side-to-side as you pull.
      Ask FixBot
Clay Eickemeyer
108,052 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 132
All Time: 2,674
