Dell Latitude 7410 Fan Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
90
All Time:
1,409
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove or replace the fan in your Dell Latitude 7410 laptop.
If your laptop overheats, or makes rattling noises when the fan is running, you might need to replace or clean it.
To replace the heatsink, follow this guide.
Parts
Tools
    1. Dell Latitude 7410 Fan Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      Ask FixBot
    1. Dell Latitude 7410 Fan Replacement, Unfasten the back cover: step 2, image 1 of 1
      • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
      Ask FixBot
    2. Dell Latitude 7410 Fan Replacement, Insert an opening pick: step 3, image 1 of 2 Dell Latitude 7410 Fan Replacement, Insert an opening pick: step 3, image 2 of 2
      • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
      Ask FixBot
    3. Dell Latitude 7410 Fan Replacement, Unclip the right edge: step 4, image 1 of 2 Dell Latitude 7410 Fan Replacement, Unclip the right edge: step 4, image 2 of 2
      • Slide your pick along the right edge to release the clips securing the back cover.
      Ask FixBot
    4. Dell Latitude 7410 Fan Replacement, Unclip the left edge: step 5, image 1 of 3 Dell Latitude 7410 Fan Replacement, Unclip the left edge: step 5, image 2 of 3 Dell Latitude 7410 Fan Replacement, Unclip the left edge: step 5, image 3 of 3
      • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
      • Slide your pick along the left edge to release the clips.
      Ask FixBot
    5. Dell Latitude 7410 Fan Replacement, Unclip the back edge: step 6, image 1 of 3 Dell Latitude 7410 Fan Replacement, Unclip the back edge: step 6, image 2 of 3 Dell Latitude 7410 Fan Replacement, Unclip the back edge: step 6, image 3 of 3
      • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
      • Slide your pick toward the left hinge until the second clip releases.
      Ask FixBot
    6. Dell Latitude 7410 Fan Replacement, Unclip the front edge: step 7, image 1 of 2 Dell Latitude 7410 Fan Replacement, Unclip the front edge: step 7, image 2 of 2
      • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
      • Slide your pick toward the right edge until the front edge releases from the frame.
      Ask FixBot
    7. Dell Latitude 7410 Fan Replacement, Remove the back cover: step 8, image 1 of 2 Dell Latitude 7410 Fan Replacement, Remove the back cover: step 8, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Dell Latitude 7410 Fan Replacement, Disconnect the battery: step 9, image 1 of 2 Dell Latitude 7410 Fan Replacement, Disconnect the battery: step 9, image 2 of 2
      • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
      Ask FixBot
    1. Dell Latitude 7410 Fan Replacement, Disconnect the fan: step 10, image 1 of 3 Dell Latitude 7410 Fan Replacement, Disconnect the fan: step 10, image 2 of 3 Dell Latitude 7410 Fan Replacement, Disconnect the fan: step 10, image 3 of 3
      • Use a spudger to press on alternating sides of the fan connector to "walk" it out of its socket.
      Ask FixBot
    2. Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: step 11, image 1 of 3 Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: step 11, image 2 of 3 Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: step 11, image 3 of 3
      • Use your Phillips screwdriver to remove the 3 mm screw securing the WLAN connector cover.
      • Remove the cover.
      Ask FixBot
    3. Dell Latitude 7410 Fan Replacement, Unfasten the fan: step 12, image 1 of 1
      • Use your Phillips screwdriver to remove the two 3 mm screws securing the fan.
      Ask FixBot
    4. Dell Latitude 7410 Fan Replacement, Remove the fan: step 13, image 1 of 3 Dell Latitude 7410 Fan Replacement, Remove the fan: step 13, image 2 of 3 Dell Latitude 7410 Fan Replacement, Remove the fan: step 13, image 3 of 3
      • Slide the fan out from the heatsink and remove it.
      Ask FixBot
Clay Eickemeyer
108,052 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 90
All Time: 1,409
