Dell Latitude 7410 Battery Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
42
Past 30 Days:
266
All Time:
3,802
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn out or damaged battery in your Dell Latitude 7410 laptop.
If your laptop dies quickly or doesn't hold a charge, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
Parts
Tools
    1. Dell Latitude 7410 Battery Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      Ask FixBot
    1. Dell Latitude 7410 Battery Replacement, Unfasten the back cover: step 2, image 1 of 1
      • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
      Ask FixBot
    2. Dell Latitude 7410 Battery Replacement, Insert an opening pick: step 3, image 1 of 2 Dell Latitude 7410 Battery Replacement, Insert an opening pick: step 3, image 2 of 2
      • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
      Ask FixBot
    3. Dell Latitude 7410 Battery Replacement, Unclip the right edge: step 4, image 1 of 2 Dell Latitude 7410 Battery Replacement, Unclip the right edge: step 4, image 2 of 2
      • Slide your pick along the right edge to release the clips securing the back cover.
      Ask FixBot
    4. Dell Latitude 7410 Battery Replacement, Unclip the left edge: step 5, image 1 of 3 Dell Latitude 7410 Battery Replacement, Unclip the left edge: step 5, image 2 of 3 Dell Latitude 7410 Battery Replacement, Unclip the left edge: step 5, image 3 of 3
      • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
      • Slide your pick along the left edge to release the clips.
      Ask FixBot
    5. Dell Latitude 7410 Battery Replacement, Unclip the back edge: step 6, image 1 of 3 Dell Latitude 7410 Battery Replacement, Unclip the back edge: step 6, image 2 of 3 Dell Latitude 7410 Battery Replacement, Unclip the back edge: step 6, image 3 of 3
      • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
      • Slide your pick toward the left hinge until the second clip releases.
      Ask FixBot
    6. Dell Latitude 7410 Battery Replacement, Unclip the front edge: step 7, image 1 of 2 Dell Latitude 7410 Battery Replacement, Unclip the front edge: step 7, image 2 of 2
      • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
      • Slide your pick toward the right edge until the front edge releases from the frame.
      Ask FixBot
    7. Dell Latitude 7410 Battery Replacement, Remove the back cover: step 8, image 1 of 2 Dell Latitude 7410 Battery Replacement, Remove the back cover: step 8, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Dell Latitude 7410 Battery Replacement, Disconnect the battery: step 9, image 1 of 2 Dell Latitude 7410 Battery Replacement, Disconnect the battery: step 9, image 2 of 2
      • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
      Ask FixBot
    1. Dell Latitude 7410 Battery Replacement, Unfasten the battery: step 10, image 1 of 1
      • Use your Phillips screwdriver to loosen the four captive screws securing the battery.
      Ask FixBot
    2. Dell Latitude 7410 Battery Replacement, Remove the battery: step 11, image 1 of 2 Dell Latitude 7410 Battery Replacement, Remove the battery: step 11, image 2 of 2
      • Remove the battery.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Clay Eickemeyer
108,178 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 266
All Time: 3,802
