Introduction
Go to step 1 ↓A replacement for the Dell Latitude 7400's wireless card may be necessary if the device is unable to connect to a wireless network, or to a Bluetooth device.
The wireless card is located inside of the Dell Latitude 7400 and provides the ability to connect to wireless networks, as well as other wireless devices. Like many computer parts, the wireless card can experience a failure in its function over time due to physical/ mechanical failures, damage to the unit itself, or the inability to maintain a good connection.
This section details the process to replace the wireless card of the the Dell Latitude 7400. Care should be used when replacing the wireless card, as it will require you to manipulate both small wires and screws. Following these steps will help restore proper wireless functionality to the device.
Tools
Spudger4.9
Lay the laptop on a flat hard surface facing downward.
Use a Phillips #0 screwdriver to remove the eight 3 mm screws that secure the lower case.
Lift the lower case off and set that aside.
Use a Phillips #0 screwdriver to remove the single screw (M2 × 3 mm) securing the wireless card.
Remove the wireless card bracket.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
