Dell Latitude 7400 Fan Replacement
    1. Dell Latitude 7400 Fan Replacement, Battery: step 1, image 1 of 3 Dell Latitude 7400 Fan Replacement, Battery: step 1, image 2 of 3 Dell Latitude 7400 Fan Replacement, Battery: step 1, image 3 of 3
      • Lay the laptop on a flat hard surface facing downward.
      • Use a Phillips #0 screwdriver to remove the eight 3 mm screws that secure the lower case.
      • Lift the lower case off and set that aside.
      Ask FixBot
    2. Dell Latitude 7400 Fan Replacement: step 2, image 1 of 3 Dell Latitude 7400 Fan Replacement: step 2, image 2 of 3 Dell Latitude 7400 Fan Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to loosen the two 3 mm captive screws that secure the battery.
      • The screws will not remove completely, so just loosen them enough to lift battery.
      • Gently grip the battery connector loop and lift it to disconnect the battery connector.
      • Lift the battery up and out.
      Ask FixBot
    1. Dell Latitude 7400 Fan Replacement, Fan: step 3, image 1 of 3 Dell Latitude 7400 Fan Replacement, Fan: step 3, image 2 of 3 Dell Latitude 7400 Fan Replacement, Fan: step 3, image 3 of 3
      • Remove the three 2 mm Phillips screws that secure the fan.
      • Lift the fan up and out of the laptop.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 114
All Time: 542
