Dell Latitude 7400 Display Assembly Replacement
    1. Dell Latitude 7400 Display Assembly Replacement, Battery: step 1, image 1 of 3 Dell Latitude 7400 Display Assembly Replacement, Battery: step 1, image 2 of 3 Dell Latitude 7400 Display Assembly Replacement, Battery: step 1, image 3 of 3
      • Lay the laptop on a flat hard surface facing downward.
      • Use a Phillips #0 screwdriver to remove the eight 3 mm screws that secure the lower case.
      • Lift the lower case off and set that aside.
      Ask FixBot
    2. Dell Latitude 7400 Display Assembly Replacement: step 2, image 1 of 3 Dell Latitude 7400 Display Assembly Replacement: step 2, image 2 of 3 Dell Latitude 7400 Display Assembly Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to loosen the two 3 mm captive screws that secure the battery.
      • The screws will not remove completely, so just loosen them enough to lift battery.
      • Gently grip the battery connector loop and lift it to disconnect the battery connector.
      • Lift the battery up and out.
      Ask FixBot
    1. Dell Latitude 7400 Display Assembly Replacement, Wireless Card: step 3, image 1 of 2 Dell Latitude 7400 Display Assembly Replacement, Wireless Card: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the single screw (M2 × 3 mm) securing the wireless card.
      • Remove the wireless card bracket.
      Ask FixBot
    2. Dell Latitude 7400 Display Assembly Replacement: step 4, image 1 of 1
      • Use tweezers or the point of a spudger to lift and disconnect the black and white antenna cables from their sockets on the wireless card.
      Ask FixBot
    3. Dell Latitude 7400 Display Assembly Replacement: step 5, image 1 of 1
      • Holding both sides of the card, carefully slide it out of the slot at an angle.
      • If the card feels stuck, gently increase pressure to loosen it from the foam. Do not force it.
      Ask FixBot
    1. Dell Latitude 7400 Display Assembly Replacement, Display Assembly: step 6, image 1 of 3 Dell Latitude 7400 Display Assembly Replacement, Display Assembly: step 6, image 2 of 3 Dell Latitude 7400 Display Assembly Replacement, Display Assembly: step 6, image 3 of 3
      • Use a Phillips #0 screwdriver to loosen the 3 mm screw securing the display connector bracket.
      • Remove the bracket.
      • Use tweezers to lift the connector pull tab and disconnect the display connector.
      Ask FixBot
    2. Dell Latitude 7400 Display Assembly Replacement: step 7, image 1 of 2 Dell Latitude 7400 Display Assembly Replacement: step 7, image 2 of 2
      • Use a Phillips #0 screwdriver to loosen the six 3 mm captive screws securing the two hinges to the motherboard.
      Ask FixBot
    3. Dell Latitude 7400 Display Assembly Replacement: step 8, image 1 of 2 Dell Latitude 7400 Display Assembly Replacement: step 8, image 2 of 2
      • Carefully open the computer screen from the body, holding the hinges in place to secure them while tilting.
      • With the keyboard facing toward you, pull the bottom computer case from the screen hinges to remove it entirely.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Devinn Wilson
97 Reputation
1 Guide authored
UW Tacoma, Team E-6, Rose Winter 2026 Member of UW Tacoma, Team E-6, Rose Winter 2026
UWT-ROSE-W26SEG6
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 96
All Time: 367
