Dell Latitude 7400 CMOS Battery Replacement
  1. Dell Latitude 7400 CMOS Battery Replacement, Battery: step 1, image 1 of 3 Dell Latitude 7400 CMOS Battery Replacement, Battery: step 1, image 2 of 3 Dell Latitude 7400 CMOS Battery Replacement, Battery: step 1, image 3 of 3
    • Lay the laptop on a flat hard surface facing downward.
    • Use a Phillips #0 screwdriver to remove the eight 3 mm screws that secure the lower case.
    • Lift the lower case off and set that aside.
    Ask FixBot
  2. Dell Latitude 7400 CMOS Battery Replacement: step 2, image 1 of 3 Dell Latitude 7400 CMOS Battery Replacement: step 2, image 2 of 3 Dell Latitude 7400 CMOS Battery Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to loosen the two 3 mm captive screws that secure the battery.
    • The screws will not remove completely, so just loosen them enough to lift battery.
    • Gently grip the battery connector loop and lift it to disconnect the battery connector.
    • Lift the battery up and out.
    Ask FixBot
  3. Dell Latitude 7400 CMOS Battery Replacement, CMOS Battery: step 3, image 1 of 2 Dell Latitude 7400 CMOS Battery Replacement, CMOS Battery: step 3, image 2 of 2
    • Lift the black locking flap that secures the I/O board ribbon cable.
    • Disconnect the ribbon cable.
    Ask FixBot
  4. Dell Latitude 7400 CMOS Battery Replacement: step 4, image 1 of 2 Dell Latitude 7400 CMOS Battery Replacement: step 4, image 2 of 2
    • Gently pull on the JST connector to disconnect it and remove the CMOS battery completely.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 35
All Time: 271
