Dell Latitude 7350 Battery Replacement
    1. Dell Latitude 7350 Battery Replacement, Lower Case: step 1, image 1 of 1
      • Remove the following ten T5 screws securing the lower case to the upper case.
      • Two will be 6mm, eight will be 3mm in length.
      Ask FixBot
    2. Dell Latitude 7350 Battery Replacement: step 2, image 1 of 2 Dell Latitude 7350 Battery Replacement: step 2, image 2 of 2
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case.
      Ask FixBot
    1. Dell Latitude 7350 Battery Replacement, Battery Replacement: step 3, image 1 of 1
      • Disconnect the battery cable.
      Ask FixBot
    2. Dell Latitude 7350 Battery Replacement: step 4, image 1 of 1
      • Use a PH1 (phillips) bit to unscrew four screws on the battery assembly tabs.
      Ask FixBot
    3. Dell Latitude 7350 Battery Replacement: step 5, image 1 of 1
      • Take out the battery.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 57
All Time: 2,221
