This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Dell Latitude 5591 PC Build
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
67
All Time:
298
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide explains how to assemble a Restart PC using a Dell Latitude 5591 motherboard: wiring the power button and LED, adding a USB expansion card and a SATA expansion card, and then securing the assembly into the housing.
      • Change the BIOS battery and secure it using double-sided tape.
      • Add a RAM stick.
      • Add a Wi-Fi card.
      • Connect the Wi-Fi antennas, as booting the board without these antennas could damage the Wi-Fi card.
      • Boot the board with the Windows drive already installed (it has a sticky note).
      Ask FixBot
    1. Dell Latitude 5591 PC Build, Connect the power port: step 2, image 1 of 2 Dell Latitude 5591 PC Build, Connect the power port: step 2, image 2 of 2
      • Remove the black sheath.
      • Warning!!! Do not cut any cables.
      • Connect the port to the motherboard.
      Ask FixBot
    2. Dell Latitude 5591 PC Build, Black plastic removal: step 3, image 1 of 3 Dell Latitude 5591 PC Build, Black plastic removal: step 3, image 2 of 3 Dell Latitude 5591 PC Build, Black plastic removal: step 3, image 3 of 3
      • Remove the black plastics from both sides of the button board.
      • Remove the rubber that is around the button and the LED.
      • Remove the yellow adhesive from the rubber.
      Ask FixBot
    3. Dell Latitude 5591 PC Build, Preparing the button wires: step 4, image 1 of 1
      • Cut the twisted wires.
      • 35cm for the LED.
      • 42cm for the button.
      • Strip and tin the 4 wire ends.
      Ask FixBot
    4. Dell Latitude 5591 PC Build, Soldering the button and LED: step 5, image 1 of 3 Dell Latitude 5591 PC Build, Soldering the button and LED: step 5, image 2 of 3 Dell Latitude 5591 PC Build, Soldering the button and LED: step 5, image 3 of 3
      • Solder the black and white wires for the button and front LED (see photo).
      • Test the button solder joints using the multimeter in "continuity tester" mode.
      • Connect the alligator clips to the black and white wires.
      • Press the original button. If the multimeter beeps, it's good, and you can move on to the next step.
      Ask FixBot
    5. Dell Latitude 5591 PC Build, Button and LED Soldering (continued): step 6, image 1 of 3 Dell Latitude 5591 PC Build, Button and LED Soldering (continued): step 6, image 2 of 3 Dell Latitude 5591 PC Build, Button and LED Soldering (continued): step 6, image 3 of 3
      • Plug in the PC and try to start it to test the LED polarity; the LED positive (the longer leg) goes to the white wire.
      • Add the heat shrink tubing.
      • Solder the LED.
      • Heat the heat shrink tubing with the heat gun.
      Ask FixBot
    6. Dell Latitude 5591 PC Build, Soldering the button and LED (continued): step 7, image 1 of 2 Dell Latitude 5591 PC Build, Soldering the button and LED (continued): step 7, image 2 of 2
      • Use a hot glue gun to apply glue over the solder joints to reinforce them.
      • The original button must remain accessible.
      • Perform a final check to ensure everything is working properly.
      Ask FixBot
    7. Dell Latitude 5591 PC Build, Mounting the board onto the grid: step 8, image 1 of 2 Dell Latitude 5591 PC Build, Mounting the board onto the grid: step 8, image 2 of 2
      • Drive the 2 short M3 Torx screws.
      • Drive the 3 M2 Phillips screws.
      Ask FixBot
    8. Dell Latitude 5591 PC Build, Front Panel Socket Installation: step 9, image 1 of 3 Dell Latitude 5591 PC Build, Front Panel Socket Installation: step 9, image 2 of 3 Dell Latitude 5591 PC Build, Front Panel Socket Installation: step 9, image 3 of 3
      • Deburr the holes for the USB extension using a Phillips screwdriver.
      • Insert the USB-A extension into its slot, with the long cable from the blue box in the bottom beige shelf.
      • Ensure that the "blue bars" of the extension are facing upward (see photo).
      • Use 2 Phillips m3 screws to secure the USB extension.
      Ask FixBot
    9. Dell Latitude 5591 PC Build, Gluing the LED: step 10, image 1 of 3 Dell Latitude 5591 PC Build, Gluing the LED: step 10, image 2 of 3 Dell Latitude 5591 PC Build, Gluing the LED: step 10, image 3 of 3
      • Glue the LED using the glue gun.
      • Try to do it as neatly as possible... not like I did.
      Ask FixBot
    10. Dell Latitude 5591 PC Build, Fastening the grille in the case: step 11, image 1 of 1
      • Drive 4 short M3x6 Torx screws WITHOUT TIGHTENING.
      • This keeps the grille in place for the next step.
      Ask FixBot
    11. Dell Latitude 5591 PC Build, Securing the grille in the case (continued): step 12, image 1 of 2 Dell Latitude 5591 PC Build, Securing the grille in the case (continued): step 12, image 2 of 2
      • Flip the assembly over.
      • Remove one screw.
      • Insert a drop of threadlocker.
      • Reinstall the screw, still WITHOUT TIGHTENING.
      • Repeat the green dots for the 4 M3 screws.
      • Tighten the 4 screws one by one.
      Ask FixBot
    12. Dell Latitude 5591 PC Build, Adding the SATA extension: step 13, image 1 of 3 Dell Latitude 5591 PC Build, Adding the SATA extension: step 13, image 2 of 3 Dell Latitude 5591 PC Build, Adding the SATA extension: step 13, image 3 of 3
      • Route the extension under the motherboard.
      • Connect the extension to the original connector.
      • Hide the connector under the motherboard.
      Ask FixBot
    13. Dell Latitude 5591 PC Build, USB extension cable routing: step 14, image 1 of 2 Dell Latitude 5591 PC Build, USB extension cable routing: step 14, image 2 of 2
      • Route the USB cables under the motherboard.
      • Connect the various cables to the corresponding ports using the adapters.
      • 90° horizontal adapter.
      • USB-C 90° horizontal adapter.
      • USB-A 3.0 180° adapter.
      Ask FixBot
    14. Dell Latitude 5591 PC Build, Adding connector blocks: step 15, image 1 of 3 Dell Latitude 5591 PC Build, Adding connector blocks: step 15, image 2 of 3 Dell Latitude 5591 PC Build, Adding connector blocks: step 15, image 3 of 3
      • Add a drop of threadlocker.
      • Screw in one short M3 Torx screw per block WITHOUT TIGHTENING.
      • Once all blocks are installed, tighten the screws one by one.
      • 1x hub block.
      • 1x USB-C power block.
      • 1x DELL air vent block.
      • 1x HDMI block.
      • 1x RJ45 block.
      Ask FixBot
    15. Dell Latitude 5591 PC Build, Adding connector blocks (continued): step 16, image 1 of 2 Dell Latitude 5591 PC Build, Adding connector blocks (continued): step 16, image 2 of 2
      • Connect the magnetic-to-USB-C adapter.
      • Preferably use the one marked "FOR DELL". The "FOR HP" versions are not compatible with certain cards.
      • Then, connect the USB-C expansion card.
      Ask FixBot
    16. Dell Latitude 5591 PC Build, Cable tie on cables: step 17, image 1 of 3 Dell Latitude 5591 PC Build, Cable tie on cables: step 17, image 2 of 3 Dell Latitude 5591 PC Build, Cable tie on cables: step 17, image 3 of 3
      • Add a cable tie to the HDMI cables.
      • Cut off the excess with flush cutters.
      • Hide the "knot" under the cable.
      Ask FixBot
    17. Dell Latitude 5591 PC Build, Cable routing: step 18, image 1 of 1
      • Cable routing aid.
      Ask FixBot
    18. Dell Latitude 5591 PC Build, Adding the SSD: step 19, image 1 of 2 Dell Latitude 5591 PC Build, Adding the SSD: step 19, image 2 of 2
      • Connect the SSD.
      • Secure the three 3x6 mm Phillips screws.
      Ask FixBot
    19. Dell Latitude 5591 PC Build, Adding Speakers: step 20, image 1 of 1
      • In our batch of PCs, we didn't have any speakers, which is why they are missing from the photos.
      • Secure the speakers using screws. No idea which ones... good luck ;).
      • Connect the speakers and hide the cable (see photo).
      Ask FixBot
    20. Dell Latitude 5591 PC Build, Adding dust covers: step 21, image 1 of 3 Dell Latitude 5591 PC Build, Adding dust covers: step 21, image 2 of 3 Dell Latitude 5591 PC Build, Adding dust covers: step 21, image 3 of 3
      • Secure the air duct with 2 M2 Phillips screws.
      • Repeat the green points for the dust cover.
      Ask FixBot
    21. Dell Latitude 5591 PC Build, Adding the Wi-Fi antennas: step 22, image 1 of 3 Dell Latitude 5591 PC Build, Adding the Wi-Fi antennas: step 22, image 2 of 3 Dell Latitude 5591 PC Build, Adding the Wi-Fi antennas: step 22, image 3 of 3
      • Glue the antennas in place using a glue gun.
      • Be careful: for the left antenna, it may be necessary to trim a piece off. Only cut where there are no electronic traces.
      • Connect the antennas.
      • Tuck the cables under the motherboard.
      Ask FixBot
    22. Dell Latitude 5591 PC Build, Grounding block installation: step 23, image 1 of 1
      • Cut a grounding block.
      • Stick the block down.
      Ask FixBot
    23. Dell Latitude 5591 PC Build, Installing the upper plate: step 24, image 1 of 2 Dell Latitude 5591 PC Build, Installing the upper plate: step 24, image 2 of 2
      • Install the upper plate.
      • Secure with 4 black M3 Phillips FHC screws (skip this step if parts are missing).
      Ask FixBot
    24. Dell Latitude 5591 PC Build, You're all done!!: step 25, image 1 of 1
      • Time for the next one or… a coffee.
      Ask FixBot
Finish Line
Modixia
1,954 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 67
All Time: 298
