Dell Latitude 5580 Lower Case Replacement
    1. Dell Latitude 5580 Lower Case Replacement, Lower Case: step 1, image 1 of 3 Dell Latitude 5580 Lower Case Replacement, Lower Case: step 1, image 2 of 3 Dell Latitude 5580 Lower Case Replacement, Lower Case: step 1, image 3 of 3
      • Orient your laptop so that you have access to the lower case, with the vents facing upwards.
      • Use a Phillips screwdriver to loosen the eight screws securing the bottom cover.
      • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
      • Insert the end of an iFixit opening tool or an opening pick into the seam between the bottom and top case to release the clips holding them together.
      • Slide the opening tool or pick around the edge of the laptop until the case is fully released.
      • Remove the lower case.
      Ask FixBot
Connor Bassolino
25,364 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 32
All Time: 166
