Dell Latitude 5580 Display Replacement
    1. Dell Latitude 5580 Display Replacement, Battery: step 1, image 1 of 3 Dell Latitude 5580 Display Replacement, Battery: step 1, image 2 of 3 Dell Latitude 5580 Display Replacement, Battery: step 1, image 3 of 3
      • Orient your laptop so that you have access to the bottom cover, with the fan vents facing upwards.
      • Use a Phillips #00 screwdriver to loosen the eight screws securing the bottom cover.
      • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
      • Insert the end of an iFixit opening tool or opening picks into the seam between the bottom and top case to release the clips holding them together.
      • Slide the opening tool or pick around the edge of the laptop until it is fully separated.
      • Remove the bottom cover.
      Ask FixBot
    2. Dell Latitude 5580 Display Replacement: step 2, image 1 of 3 Dell Latitude 5580 Display Replacement: step 2, image 2 of 3 Dell Latitude 5580 Display Replacement: step 2, image 3 of 3
      • Remove the single Phillips #00 screw that is holding down the battery.
      Ask FixBot
    3. Dell Latitude 5580 Display Replacement: step 3, image 1 of 2 Dell Latitude 5580 Display Replacement: step 3, image 2 of 2
      • Use the pull tab to gently pull the battery cable out of its socket.
      Ask FixBot
    4. Dell Latitude 5580 Display Replacement: step 4, image 1 of 2 Dell Latitude 5580 Display Replacement: step 4, image 2 of 2
      • Remove the old battery.
      • To install the battery connection cable, push gently into the original connection port to connect the replacement battery to the computer. Tuck in the battery connection cable underneath the plastic frame next to the battery.
      Ask FixBot
    1. Dell Latitude 5580 Display Replacement, Display: step 5, image 1 of 2 Dell Latitude 5580 Display Replacement, Display: step 5, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 3.1 mm screws holding the fan down.
      Ask FixBot
    2. Dell Latitude 5580 Display Replacement: step 6, image 1 of 3 Dell Latitude 5580 Display Replacement: step 6, image 2 of 3 Dell Latitude 5580 Display Replacement: step 6, image 3 of 3
      • Use the point of a spudger to push on alternating sides of the connector to "walk" the JST connector out of its socket.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      • If you're having trouble, try rocking the connector side-to-side to loosen it.
      • Remove the fan from your laptop.
      Ask FixBot
    3. Dell Latitude 5580 Display Replacement: step 7, image 1 of 3 Dell Latitude 5580 Display Replacement: step 7, image 2 of 3 Dell Latitude 5580 Display Replacement: step 7, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the single 3.1 mm screw holding down the green Wi-Fi card.
      • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the coaxial cable connectors on the Wi-Fi card (as close to the head as possible) and lift straight up from the board.
      • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
      • Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again. Don't force the connector down or you may damage it.
      • Slide the Wi-Fi card out of the socket to remove it.
      Ask FixBot
    4. Dell Latitude 5580 Display Replacement: step 8, image 1 of 3 Dell Latitude 5580 Display Replacement: step 8, image 2 of 3 Dell Latitude 5580 Display Replacement: step 8, image 3 of 3
      • Remove the two 3.00 mm Phillips #00 screws securing the cover to the display cable port.
      • Pull the black tab on the display cable connector to safely separate from the motherboard.
      Ask FixBot
    5. Dell Latitude 5580 Display Replacement: step 9, image 1 of 3 Dell Latitude 5580 Display Replacement: step 9, image 2 of 3 Dell Latitude 5580 Display Replacement: step 9, image 3 of 3
      • Remove the two 3.00 mm Phillips #00 screws securing the hinge covers.
      • Slide the hinge covers down and off the laptop. Since they have a slight “lip” wrapping around the hinge, you may have to prop the laptop up slightly.
      Ask FixBot
    6. Dell Latitude 5580 Display Replacement: step 10, image 1 of 2 Dell Latitude 5580 Display Replacement: step 10, image 2 of 2
      • Remove a total of six 6.1 mm Phillips #00 screws from both hinges.
      Ask FixBot
    7. Dell Latitude 5580 Display Replacement: step 11, image 1 of 3 Dell Latitude 5580 Display Replacement: step 11, image 2 of 3 Dell Latitude 5580 Display Replacement: step 11, image 3 of 3
      • Move the Wi-Fi card wiring and display cable away from the hinge.
      • Lift the display and separate it from the rest of the laptop.
      Ask FixBot
    8. Dell Latitude 5580 Display Replacement: step 12, image 1 of 2 Dell Latitude 5580 Display Replacement: step 12, image 2 of 2
      • Insert the end of a spudger in between the bezel and the screen and work around the edges of the bezel, separating it from the screen.
      • Remove the bezel completely.
      • Be careful when removing the bezel as it can easily crack or break. You will need it when you replace the screen.
      Ask FixBot
    9. Dell Latitude 5580 Display Replacement: step 13, image 1 of 3 Dell Latitude 5580 Display Replacement: step 13, image 2 of 3 Dell Latitude 5580 Display Replacement: step 13, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four 3.0 mm screws securing the screen.
      • Carefully rotate the screen over, pivoting at the bottom where the cable connects.
      Ask FixBot
    10. Dell Latitude 5580 Display Replacement: step 14, image 1 of 3 Dell Latitude 5580 Display Replacement: step 14, image 2 of 3 Dell Latitude 5580 Display Replacement: step 14, image 3 of 3
      • Carefully disconnect the display ribbon connector.
      • Separate the adhered ribbon cable from the panel.
      • Remove the screen.
      Ask FixBot
To reassemble your device, install your new display by connecting the display cable and follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ben Andrews
231 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 108
All Time: 668
