Dell Latitude 5521 Battery Replacement
    1. Dell Latitude 5521 Battery Replacement, Base Cover Removal: step 1, image 1 of 3 Dell Latitude 5521 Battery Replacement, Base Cover Removal: step 1, image 2 of 3 Dell Latitude 5521 Battery Replacement, Base Cover Removal: step 1, image 3 of 3
      • Remove the 9 phillips #0 screws from the bottom of the case.
      • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
      • Once removed you will have access to the contents of your case.
      Ask FixBot
    1. Dell Latitude 5521 Battery Replacement, Battery removal: step 2, image 1 of 3 Dell Latitude 5521 Battery Replacement, Battery removal: step 2, image 2 of 3 Dell Latitude 5521 Battery Replacement, Battery removal: step 2, image 3 of 3
      • Locate battery in case.
      • Locate three screws that will need to be removed.
      • Locate ribbon attached to battery cable a the top left of the battery and pull straight up on the ribbon.
      • Remove all three screws holding the battery on the main board.
      Ask FixBot
Michael Engle
461 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 59
All Time: 2,484
