Dell Latitude 5490 WLAN (WiFi Card) Replacement
    1. Dell Latitude 5490 WLAN (WiFi Card) Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 1 of 3 Dell Latitude 5490 WLAN (WiFi Card) Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 2 of 3 Dell Latitude 5490 WLAN (WiFi Card) Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 3 of 3
      • Power off the laptop before beginning the disassembly process.
      • Close the device and flip the laptop over so the backplate is facing up.
      Ask FixBot
    2. Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 2, image 1 of 2 Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 2, image 2 of 2
      • Using a Phillips #0 Screwdriver, loosen all eight captive screws in the backplate.
      • You do not need to fully remove the screws. Instead, unscrew them until you can easily jostle the screws.
      Ask FixBot
    3. Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 3, image 1 of 2 Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 3, image 2 of 2
      • Using the spudger, pry the backplate from the laptop starting from external chassis (the back side of the laptop).
      • Continue prying in a clockwise direction around the backplate until it is able to be removed with just your hands.
      • Remove the backplate and put it aside for reassembly.
      Ask FixBot
    4. Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 4, image 1 of 2 Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 4, image 2 of 2
      • Using your finger, remove the battery connector using the handle found on top.
      • You do not need to remove the connector completely from the laptop. Doing so may result in damage to your computer. Instead, pull the handle so the connector is suspended above the pins.
      Ask FixBot
    5. Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 5, image 1 of 1
      • Hold down the power button for 15 seconds to discharge the remaining electricity within the laptop.
      Ask FixBot
    1. Dell Latitude 5490 WLAN (WiFi Card) Replacement, WLAN (WiFi Card): step 6, image 1 of 1
      • Remove the 4 mm screw holding the bracket above the WLAN card with a Phillips #0 screwdriver.
      • Be careful with the antenna connectors located under the bracket. They are fragile. If damaged, you will not be able to access Wi-Fi.
      Ask FixBot
    2. Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 7, image 1 of 3 Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 7, image 2 of 3 Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 7, image 3 of 3
      • Carefully remove both antenna connectors. Ensure that you pull the antenna connectors straight up from the socket.
      • Using angled tweezers, hook one end of the tweezer under the connector. Set the other side at the end of the connector on the WLAN card. Keeping the tweezers flat, lightly squeeze.
      • These connectors are extremely fragile; ensure that they are aligned properly.
      • For reassembly, ensure that the antenna connectors are aligned above the sockets and press down gently. There should be a slight click. There should not be tension or resistance while doing so.
      Ask FixBot
    3. Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 8, image 1 of 2 Dell Latitude 5490 WLAN (WiFi Card) Replacement: step 8, image 2 of 2
      • Carefully slide the WLAN card out from the rear side, from the end where the antennas and bracket were.
      • The WLAN card should come out easily with no tension.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 45
All Time: 295
