Dell Latitude 5490 SSD Replacement
    1. Dell Latitude 5490 SSD Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 1 of 3 Dell Latitude 5490 SSD Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 2 of 3 Dell Latitude 5490 SSD Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 3 of 3
      • Power off the laptop before beginning the disassembly process.
      • Close the device and flip the laptop over so the backplate is facing up.
      Ask FixBot
    2. Dell Latitude 5490 SSD Replacement: step 2, image 1 of 2 Dell Latitude 5490 SSD Replacement: step 2, image 2 of 2
      • Using a Phillips #0 Screwdriver, loosen all eight captive screws in the backplate.
      • You do not need to fully remove the screws. Instead, unscrew them until you can easily jostle the screws.
      Ask FixBot
    3. Dell Latitude 5490 SSD Replacement: step 3, image 1 of 2 Dell Latitude 5490 SSD Replacement: step 3, image 2 of 2
      • Using the spudger, pry the backplate from the laptop starting from external chassis (the back side of the laptop).
      • Continue prying in a clockwise direction around the backplate until it is able to be removed with just your hands.
      • Remove the backplate and put it aside for reassembly.
      Ask FixBot
    4. Dell Latitude 5490 SSD Replacement: step 4, image 1 of 2 Dell Latitude 5490 SSD Replacement: step 4, image 2 of 2
      • Using your finger, remove the battery connector using the handle found on top.
      • You do not need to remove the connector completely from the laptop. Doing so may result in damage to your computer. Instead, pull the handle so the connector is suspended above the pins.
      Ask FixBot
    5. Dell Latitude 5490 SSD Replacement: step 5, image 1 of 1
      • Hold down the power button for 15 seconds to discharge the remaining electricity within the laptop.
      Ask FixBot
    1. Dell Latitude 5490 SSD Replacement, SSD (Solid State Drive): step 6, image 1 of 2 Dell Latitude 5490 SSD Replacement, SSD (Solid State Drive): step 6, image 2 of 2
      • Remove the single 4 mm screw connecting the back of the SSD to the laptop using a Phillips #0 screwdriver.
      • When the screw is removed, the SSD will be angled with an incline to one side.
      Ask FixBot
    2. Dell Latitude 5490 SSD Replacement: step 7, image 1 of 2 Dell Latitude 5490 SSD Replacement: step 7, image 2 of 2
      • Carefully slide the SSD straight out from the rear side, from the end where the screw was previously secured.
      • The SSD should come out easily with no tension.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 155
All Time: 1,005
