Dell Latitude 5490 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
38
Past 30 Days:
192
All Time:
1,137
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The battery provides a mobile power source for your laptop. Batteries will slowly lose capacity over time and replacing it can improve the lifespan of your laptop.
In this guide, we will show you how to install and replace the battery in your Dell Latitude 5490 laptop.
If your computer's charge does not last, you may need to replace the battery. An operational battery can restore your laptop to optimal condition.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Dell Latitude 5490 Battery Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 1 of 3 Dell Latitude 5490 Battery Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 2 of 3 Dell Latitude 5490 Battery Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 3 of 3
      • Power off the laptop before beginning the disassembly process.
      • Close the device and flip the laptop over so the backplate is facing up.
      Ask FixBot
    2. Dell Latitude 5490 Battery Replacement: step 2, image 1 of 2 Dell Latitude 5490 Battery Replacement: step 2, image 2 of 2
      • Using a Phillips #0 Screwdriver, loosen all eight captive screws in the backplate.
      • You do not need to fully remove the screws. Instead, unscrew them until you can easily jostle the screws.
      Ask FixBot
    3. Dell Latitude 5490 Battery Replacement: step 3, image 1 of 2 Dell Latitude 5490 Battery Replacement: step 3, image 2 of 2
      • Using the spudger, pry the backplate from the laptop starting from external chassis (the back side of the laptop).
      • Continue prying in a clockwise direction around the backplate until it is able to be removed with just your hands.
      • Remove the backplate and put it aside for reassembly.
      Ask FixBot
    4. Dell Latitude 5490 Battery Replacement: step 4, image 1 of 2 Dell Latitude 5490 Battery Replacement: step 4, image 2 of 2
      • Using your finger, remove the battery connector using the handle found on top.
      • You do not need to remove the connector completely from the laptop. Doing so may result in damage to your computer. Instead, pull the handle so the connector is suspended above the pins.
      Ask FixBot
    5. Dell Latitude 5490 Battery Replacement: step 5, image 1 of 1
      • Hold down the power button for 15 seconds to discharge the remaining electricity within the laptop.
      Ask FixBot
    1. Dell Latitude 5490 Battery Replacement, Battery: step 6, image 1 of 3 Dell Latitude 5490 Battery Replacement, Battery: step 6, image 2 of 3 Dell Latitude 5490 Battery Replacement, Battery: step 6, image 3 of 3
      • Carefully unroute the cable connecting the battery to the laptop.
      Ask FixBot
    2. Dell Latitude 5490 Battery Replacement: step 7, image 1 of 1
      • Remove the single marked 4 mm screw from the righthand side of the battery using a Phillips #0 screwdriver.
      Ask FixBot
    3. Dell Latitude 5490 Battery Replacement: step 8, image 1 of 3 Dell Latitude 5490 Battery Replacement: step 8, image 2 of 3 Dell Latitude 5490 Battery Replacement: step 8, image 3 of 3
      • Gently lift the battery out of the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 192
All Time: 1,137
