Dell Latitude 5480 RAM Replacement
    1. Dell Latitude 5480 RAM Replacement, Lower Case: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
      Ask FixBot
    2. Dell Latitude 5480 RAM Replacement: step 2, image 1 of 3 Dell Latitude 5480 RAM Replacement: step 2, image 2 of 3 Dell Latitude 5480 RAM Replacement: step 2, image 3 of 3
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry up around the perimeter of the device until the lower case fully releases.
      • Lift off the lower case.
      Ask FixBot
    1. Dell Latitude 5480 RAM Replacement, Dell Latitude 5480 Battery Disconnection: step 3, image 1 of 2 Dell Latitude 5480 RAM Replacement, Dell Latitude 5480 Battery Disconnection: step 3, image 2 of 2
      • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
      Ask FixBot
    1. Dell Latitude 5480 RAM Replacement, RAM: step 4, image 1 of 2 Dell Latitude 5480 RAM Replacement, RAM: step 4, image 2 of 2
      • Two black clips secure each RAM module in place, one on each side. Use your fingers to spread the clips away from the RAM module.
      • Repeat the previous bullet on the second module.
      • When released, the RAM modules will pop up at a slight angle.
      Ask FixBot
    2. Dell Latitude 5480 RAM Replacement: step 5, image 1 of 2 Dell Latitude 5480 RAM Replacement: step 5, image 2 of 2
      • Pull the RAM module directly out of its port.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 32
Past 30 Days: 117
All Time: 1,181
