Dell Latitude 5480 Display Replacement
    1. Dell Latitude 5480 Display Replacement, Lower Case: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
      Ask FixBot
    2. Dell Latitude 5480 Display Replacement: step 2, image 1 of 3 Dell Latitude 5480 Display Replacement: step 2, image 2 of 3 Dell Latitude 5480 Display Replacement: step 2, image 3 of 3
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry up around the perimeter of the device until the lower case fully releases.
      • Lift off the lower case.
      Ask FixBot
    1. Dell Latitude 5480 Display Replacement, Battery: step 3, image 1 of 2 Dell Latitude 5480 Display Replacement, Battery: step 3, image 2 of 2
      • Remove the four 5.6 mm Phillips screws that secure the battery.
      Ask FixBot
    2. Dell Latitude 5480 Display Replacement: step 4, image 1 of 3 Dell Latitude 5480 Display Replacement: step 4, image 2 of 3 Dell Latitude 5480 Display Replacement: step 4, image 3 of 3
      • Lift the battery up and out of the chassis.
      Ask FixBot
    1. Dell Latitude 5480 Display Replacement, Display: step 5, image 1 of 3 Dell Latitude 5480 Display Replacement, Display: step 5, image 2 of 3 Dell Latitude 5480 Display Replacement, Display: step 5, image 3 of 3
      • Insert a plastic card between the bezel and the display.
      • Slide the plastic card beneath the entire bezel to sever the adhesive that secures the bezel.
      • Lift the bezel off of the display.
      Ask FixBot
    2. Dell Latitude 5480 Display Replacement: step 6, image 1 of 3 Dell Latitude 5480 Display Replacement: step 6, image 2 of 3 Dell Latitude 5480 Display Replacement: step 6, image 3 of 3
      • Remove the four 5.6 mm Phillips head screws, one at each corner, to release the display assembly.
      • Gently lift away the display panel and set it on top of the keyboard.
      • Take care not to strain the display assemble cable.
      Ask FixBot
    3. Dell Latitude 5480 Display Replacement: step 7, image 1 of 3 Dell Latitude 5480 Display Replacement: step 7, image 2 of 3 Dell Latitude 5480 Display Replacement: step 7, image 3 of 3
      • On the bottom of the back of the display panel, remove the tape that secures the cable connecting the screen to the base of the computer.
      • Flip up the display cable locking bar.
      • Disconnect the display connector.
      • Remove the display.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 113
All Time: 1,358
