Dell Latitude 5430 Wi-Fi Card Replacement
  1. Dell Latitude 5430 Wi-Fi Card Replacement, Lower Case: step 1, image 1 of 2 Dell Latitude 5430 Wi-Fi Card Replacement, Lower Case: step 1, image 2 of 2
    • Disconnect the charger, unplug any peripheries, and power down the laptop before beginning.
    • Use a Phillips #1 screwdriver to loosen the eight M2.5x6.5 captive screws securing the lower case.
    Ask FixBot
  2. Dell Latitude 5430 Wi-Fi Card Replacement: step 2, image 1 of 2 Dell Latitude 5430 Wi-Fi Card Replacement: step 2, image 2 of 2
    • Insert an opening pick or opening tool into the seam between the lower case and chassis.
    • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
    • Remove the lower case.
    Ask FixBot
  3. Dell Latitude 5430 Wi-Fi Card Replacement, Dell Latitude 5430 Battery Disconnection: step 3, image 1 of 2 Dell Latitude 5430 Wi-Fi Card Replacement, Dell Latitude 5430 Battery Disconnection: step 3, image 2 of 2
    • Grip the battery connector pull-tab and lift it straight up to disconnect the battery.
    Ask FixBot
  4. Dell Latitude 5430 Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 2 Dell Latitude 5430 Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 2 of 2
    • Remove the single Phillips #1 2 mm x 2.5 mm screw securing the Wi-Fi card cable bracket.
    Ask FixBot
  5. Dell Latitude 5430 Wi-Fi Card Replacement: step 5, image 1 of 1
    • Use the pointed end of a spudger to lift and disconnect the antenna cable connectors.
    Ask FixBot
  6. Dell Latitude 5430 Wi-Fi Card Replacement: step 6, image 1 of 2 Dell Latitude 5430 Wi-Fi Card Replacement: step 6, image 2 of 2
    • Slide the Wi-Fi card directly out of its socket.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 27
All Time: 41
