Dell Latitude 5430 Screen Replacement
    1. Dell Latitude 5430 Screen Replacement, Lower Case: step 1, image 1 of 2 Dell Latitude 5430 Screen Replacement, Lower Case: step 1, image 2 of 2
      • Disconnect the charger, unplug any peripheries, and power down the laptop before beginning.
      • Use a Phillips #1 screwdriver to loosen the eight M2.5x6.5 captive screws securing the lower case.
      Ask FixBot
    2. Dell Latitude 5430 Screen Replacement: step 2, image 1 of 2 Dell Latitude 5430 Screen Replacement: step 2, image 2 of 2
      • Insert an opening pick or opening tool into the seam between the lower case and chassis.
      • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
      • Remove the lower case.
      Ask FixBot
    1. Dell Latitude 5430 Screen Replacement, Dell Latitude 5430 Battery Disconnection: step 3, image 1 of 2 Dell Latitude 5430 Screen Replacement, Dell Latitude 5430 Battery Disconnection: step 3, image 2 of 2
      • Grip the battery connector pull-tab and lift it straight up to disconnect the battery.
      Ask FixBot
    1. Dell Latitude 5430 Screen Replacement, Screen: step 4, image 1 of 2 Dell Latitude 5430 Screen Replacement, Screen: step 4, image 2 of 2
      • Lay the device flat and use black opening tool to pry along the bezel to remove it.
      Ask FixBot
    2. Dell Latitude 5430 Screen Replacement: step 5, image 1 of 2 Dell Latitude 5430 Screen Replacement: step 5, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the three 2.5 mm x 3 mm screws securing the display assembly to each of the two hinges.
      Ask FixBot
    3. Dell Latitude 5430 Screen Replacement: step 6, image 1 of 3 Dell Latitude 5430 Screen Replacement: step 6, image 2 of 3 Dell Latitude 5430 Screen Replacement: step 6, image 3 of 3
      • Flip over the screen and peel off the protective adhesive.
      • Flip up the locking flap securing the screen connector.
      • Disconnect the screen connector.
      • Remove the screen.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 154
All Time: 359
