Introduction
Go to step 1 ↓This guide walks you through the process of replacing the SSD in your Dell Latitude 5430, helping you restore performance or upgrade storage capacity. You’ll find clear, step-by-step instructions along with the tools and precautions needed to complete the task safely. Whether you’re troubleshooting a failing drive or simply looking for more space, this guide is designed to make the replacement straightforward and efficient.
Parts
Tools
Disconnect the charger, unplug any peripheries, and power down the laptop before beginning.
Use a Phillips #1 screwdriver to loosen the eight M2.5x6.5 captive screws securing the lower case.
Grip the battery connector pull-tab and lift it straight up to disconnect the battery.
Use a Phillips #1 screwdriver to remove the three 2 mm x 3 mm screws securing the SSD assembly.
Remove the heat shield over the SSD.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
