Dell Latitude 5411 Battery Replacement
    1. Dell Latitude 5411 Battery Replacement, Lower Case: step 1, image 1 of 1
      • Loosen all eight 2.5 mm captive Phillips #1 screws that secure the lower case.
      • As the screws are captive, they will remain in the case after being loosened.
      Ask FixBot
    2. Dell Latitude 5411 Battery Replacement: step 2, image 1 of 2 Dell Latitude 5411 Battery Replacement: step 2, image 2 of 2
      • Lift the base cover starting from the left hinge.
      • If it is hard to pull off, make sure that all the screws are loose.
      Ask FixBot
    1. Dell Latitude 5411 Battery Replacement, Battery: step 3, image 1 of 2 Dell Latitude 5411 Battery Replacement, Battery: step 3, image 2 of 2
      • Pull the battery connector pull tab straight up to disconnect the battery.
      • Remove the one 2 mm Phillips #1 screw that secures the battery.
      • Lift the battery straight up and out of the chassis.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
25,358 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
123 Members
77,499 Guides authored
1 Guide Comment
Love y'all guys!! Will be ordering the batt ASAP..!
Marissa Quintero - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 95
All Time: 1,258
